Author Topic: Mk2 16v Power steering hose woes  (Read 27432 times)
VeeDubGTI16v
Re: Mk2 16v Power steering hose woes
« Reply #30 on: 15 May 2009, 12:57 »
I don't think that was a terribly snide remark
theres your problem  :wink:
« Reply #31 on: 15 May 2009, 13:17 »
well IN MY EXPERIENCE the MK2 uses an absolutly wonderful system that involves 5 or 6 bolts to loosen, plus a really ugly T bolt thingy which has a threaded head on it.  This tends to be all bent from previous owners overdoing it trying to tension a knackered old belt, or trying to tenion it without loosening the hidden bolt round the back of the pump.
MK3 uses literally 3 bolts, one of which has a toothed wheel on it to allow you to set tension with a spanner.  OK its no clever self-tensioner system, but it works well and is infinitly easier to adjust.
The yanks have several methods for including the pas pump in with the main serp belt, but I dont really see the point personally when the stock system will work fine for years on end without needing to look at it.
Offline danny_p
« Reply #32 on: 15 May 2009, 18:48 »
i like the mk2 setup as much as pirburg carbs and the mk3 setup as much as k jet.
it would be quite easy to put the pas pump on the serpentine belt but not doing that ether.     i'm going for a nice cute polo pump then the pump can go wherever i want to put it and no parasitic load on the engine,  it only pumps when needed
all the VW's have gone bar 1.
Offline Neo Badness
  • Feet are for pedals
« Reply #33 on: 16 May 2009, 15:09 »
So what's the verdict guys? Mk3 Complete system sitting there known as working or trying to sort out the Mk2 one?
I know I need the bracket that holds the power steering pump on and the high pressure hose that leads away from it, anyone got one sitting in their shed??
Offline Neo Badness
« Reply #34 on: 16 May 2009, 15:28 »
I had to replace all my power steering hoses on my Mk2 16v & this guy made them all for me for £120..
Check out "power-steering-store" on eBay & mail the guy to see what he says.. Very helpful chappie!
Had a look on ebay for above but no luck, any chance of a link gt?
Offline Ben Lessani
« Reply #35 on: 16 May 2009, 16:25 »
If you've got a full MK3 setup - why bother trying to fix the MK2 one?
Offline danny_p
« Reply #36 on: 16 May 2009, 21:04 »
i should have a complete mk3 setup, as i must have removed one from the engine i blew up
Offline johnson6672
« Reply #37 on: 16 May 2009, 21:20 »
Pirtek do make fuel hoses, i am a mechanic in the army and have used pirtek more than once for fuel hoses for tanks!!!!!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline danny_p
« Reply #38 on: 16 May 2009, 21:33 »
i thought it sounded funny them not doing pas hoses or fuel hoses.
i mean they do gurt big hydralic lines i'm sure a gurt big hydralic line failing can have far more issues concirning the HSE than a dinky pas hose  it's not like it stops you steering or anything, tho big hydralic lines have large rams attached to bih heavy swinging things
Offline johnson6672
« Reply #39 on: 16 May 2009, 21:35 »
Great big fuel hoses with 30 psi of fuel in them!!!!
