Author Topic: Mk2 16v Power steering hose woes  (Read 27421 times)
Offline Neo Badness
  • Feet are for pedals
Re: Mk2 16v Power steering hose woes
« Reply #60 on: 20 May 2009, 17:18 »
Cheers guys, I feel a bit better now. Was def having concerns about fitting the 8v one, but when you've been to 6 scrap yards and only turned up 2 mk2's, both with manual racks you start to lose heart.
So when one popped up on the 'bay I had his arm off for it.
Will order the the pump bracket tommorow, just to clarify, this is the bracket that fits to the block?
Was quite gutting to see a spotless 5door shell never welded sitting in the scrappy. But I did score an immaculate pair of original door speaker covers for a quid though... :smiley:
« Reply #61 on: 21 May 2009, 10:25 »
thats the bracket that is bolted to the pump itself, its like a long thin metal arm?
part 10 in this piccy:
Offline Neo Badness
« Reply #62 on: 22 May 2009, 17:34 »
Nah, I've got two of them, I need the actual bracket that holds it all to the block, the un-numbered bit that all the other bits are attaching to in the diagram. Any idea part no/ proper name. I have a few names for it but none that i can repeat here :wink:
« Reply #63 on: 26 May 2009, 10:07 »
ouch, not cheap!  has to be 16v PAS one too, non-pas and a/c ones differ.
051260885A - 180€
VeeDubGTI16v
« Reply #64 on: 26 May 2009, 10:17 »
i think i have one of those, let me have a look. i recently put all the mk3 kit on so it should be somewhere
Offline Neo Badness
« Reply #65 on: 26 May 2009, 17:19 »
Let me know if you do, I still haven't got my car running and back from the garage. Starting to have mk2 withdrawl symptoms.... :sad:
