Author Topic: nightmare...  (Read 3933 times)
Offline mumbles
nightmare...
« on: 07 May 2009, 10:06 »
so my mk3 let me down big style last night...
chucking down with rain, pull up to let somone out of a space and the revs stick at 2000... I think to myself "thats odd" I rev it to see if it goes back down right and it sticks higher and takes a few seconds to come back down and again sticks at 2000rpm. person in front has pulled out so go to move off and car shudders, revs die and car dies... "sh*t!!" wont start, battery is fine (brand new yesterday) starter is turning over enginge but nothing happens.
Figure its probably dizzy. Anyone had this problem before?
it needs a new PAS belt which also drives the alternator so I know battery isn't charging properly while I'm driving and I figure that might be why the revs stuck high (the engine management trying to keep charge going to battery)...?? Is this a correct assumption?
could try cleaning throttle body... would that help?
thanks in advance for any help
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline Khare
  • The bear that khares
Re: nightmare...
« Reply #1 on: 07 May 2009, 10:09 »
full service followed by throttle body cleaning will help.
Offline mumbles
Re: nightmare...
« Reply #2 on: 07 May 2009, 10:12 »
its booked in for service on the 13th... booked it last week and its the soonest they could do it.
cheers anyway khare.
Any other ideas??
Audi A4 Sport
Offline gazpowells
Re: nightmare...
« Reply #3 on: 07 May 2009, 10:38 »
Good service will always help  :smiley:
Check all the vacum pipes going 2 the manifold mate and
Give the TB a good clean
Offline mumbles
Re: nightmare...
« Reply #4 on: 07 May 2009, 11:01 »
cheers guys. you not think its the dizzy then??
will have to somehow get the car back to mine before I can do the TB.. or anything else for that matter. Not goin to be today as the heavens have opened and the winds up to 50mph gusting to 70!
Audi A4 Sport
Offline mumbles
Re: nightmare...
« Reply #5 on: 07 May 2009, 16:57 »
dad drove me around to the car just now and took off the distributer cap to find the centre connection totally black and covered in dust. tried to clean it up but as we did the connection went back up into the cap (spring broken or worn away completely) Ordered a new cap, should be here by saturday. rotor arm cleaned up ok so not goin to get another one right now.
hopefully that will get the car goin till I can get the service on wednesday.  :grin:
thanks again for the help  :smiley:
Audi A4 Sport
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
Re: nightmare...
« Reply #6 on: 07 May 2009, 18:03 »
give the throttle body a good clean, if you dont know where it is, tell me and i'll show you in a picture
Offline mumbles
Re: nightmare...
« Reply #7 on: 07 May 2009, 21:00 »
ye, will do mate. got to wait till i get her home first tho  :smiley:
cheers, but I've already searched and found all the threads about cleanin it on here and had a look on the car when I was checking the dizzy earlier, should be straight forward enough to clean it up. :cool:
Audi A4 Sport
Offline boneybradley
  • Back in a Mk3...
Re: nightmare...
« Reply #8 on: 07 May 2009, 21:08 »
I will add the pas belt is seperate to the alty belt!! but for around £10 the pair sort them both!
Offline mumbles
Re: nightmare...
« Reply #9 on: 07 May 2009, 21:11 »
I believe BB but you sure?? there's two belts. one fat, one thin. I've got a replacement fatty. should I replace the other one too??
cheers
Audi A4 Sport
