Author Topic: nightmare...  (Read 3944 times)
Offline mumbles
Re: nightmare...
« Reply #20 on: 09 May 2009, 19:26 »
The throttle body was not actually that bad, certainly no serious build up of anything - wiped clean and shiny very easily, once it was off.  Also checked the electrical connections to it (throttle position sensor I presume) and they are fine as well.
Thanks again
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline Mikester
  • Civic Type R
Re: nightmare...
« Reply #21 on: 09 May 2009, 19:34 »
Did you just take of the air intake and wipe it out? Or remove it and do the other side of the flange?
Offline euro-gti
Re: nightmare...
« Reply #22 on: 10 May 2009, 11:15 »
i have the same problem as you with my 2.0 8v i have replaced plugs, dizzy cap, rotor arm, ht leads, coil, temp sensor, all belts and still it will drive for about 3 minuites and then start misfiring badly not drivable, no one seems to know the awserbut seems to be a comon problem,
Offline mumbles
Re: nightmare...
« Reply #23 on: 10 May 2009, 16:06 »
sorry to hear you have the same problems mate... If i find the solution it might work for you too  :smiley:
As I said tho, got a new mass flow air sensor on the way so will see if that makes any difference.
again, any suggestions welcome!
thanks
Audi A4 Sport
Offline mumbles
Re: nightmare...
« Reply #24 on: 17 May 2009, 12:14 »
finally after days of waiting for it to arrive, Mass Air Flow meter landed on my doorstep, now fitted and no change, still wont run right... ordered new coil..  :sad: fingers crossed...
Audi A4 Sport
Offline euro-gti
Re: nightmare...
« Reply #25 on: 18 May 2009, 22:29 »
ok that doesnt help then i have a new air mass sensor on the way was hoping this would be the solution to my problems, i need to get the car sorted so keep me updated as i will you if i find out the problems
Offline mumbles
Re: nightmare...
« Reply #26 on: 19 May 2009, 08:44 »
cheers mate have pm'd you. but will def post up on this thread if I find the problem... I haven't driven a car in 2 weeks now... i'm goin mad!!
Audi A4 Sport
Offline mumbles
Re: nightmare...
« Reply #27 on: 20 May 2009, 16:06 »
new coil.... no change... I'm runnin out of ideas...
Audi A4 Sport
Offline BlazinGTI
Re: nightmare...
« Reply #28 on: 20 May 2009, 16:18 »
sounds like your having fun there dude, have you had it plugged into vag-com! sounds like your chucking money at it! for 50-80quid you should be able to get it plugged in! could save money in the long run!
waht engine is it? is it the AGG?
Offline mumbles
Re: nightmare...
« Reply #29 on: 20 May 2009, 16:21 »
ye, i am chucking money at it but I need a car. no option where I live. don't have access to a vag com at the moment. just read on another thread that it may be crankshaft sensor.... worth a try.
and yes it is the AGG engine.
Audi A4 Sport
