Author Topic: car wont start ?  (Read 2823 times)
Offline widget2k4
car wont start ?
« on: 03 May 2009, 17:35 »
Hi everyone, great forum btw
just got a 2005 golf gti on friday,used it friday night and saturday without any problems at all.
parked it up last night and when i went to go in it today it wont start,the engine sounds like it has no compression,it just doesn't sound right,its not even attempting to fire at all.
also it comes up on the display STOP and makes a noise.
any ideas ?
thank you
neo66
Re: car wont start ?
« Reply #1 on: 03 May 2009, 17:36 »
There a whizzing noise by any chance??
Whats the mileage?
Offline widget2k4
« Reply #2 on: 03 May 2009, 17:41 »
53,000 miles
its not a wizzing sound as such,just doesnt sound like a normal engine turning over
neo66
« Reply #3 on: 03 May 2009, 17:46 »
Hope it aint the cam belt!?
Offline widget2k4
« Reply #4 on: 03 May 2009, 17:55 »
it does sound like it, any way of checking without stripping bits off ?
thats a great start to my nice new gti :(
Offline Cass
« Reply #5 on: 03 May 2009, 20:08 »
Coil packs ?
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline Jayy
« Reply #6 on: 03 May 2009, 20:12 »
if the cars ticking over, you will be able to see the cam belt trying to move, its on the left hand side of the engine, runs up the side
wouldnt try and start it too many times, just incase it has slipped,
coil packs im unsure of, but there under the engine cover (snaps off) and at the back of the plastic oil cover housing
best bet is check the cam belt, if not find some one with vag com...
Offline bobotheclown
« Reply #7 on: 03 May 2009, 20:36 »
Is it turning over? if not then it might the battery?
Offline widget2k4
« Reply #8 on: 03 May 2009, 20:38 »
car is turning over ok,it is not ticking over,cant see cam belt without removing the cambelt cover.
i cant see any gaps to see whether or not the cams are turning
Offline widget2k4
« Reply #9 on: 03 May 2009, 20:52 »
ok,found a cover to remove and got someone to turn engine over,camshaft is turning so the cam belt is not snapped :)
