Author Topic: car wont start ?  (Read 2824 times)
WhiteGTI
Re: car wont start ?
« Reply #10 on: 05 May 2009, 09:29 »
Have you connected the car to VAGCOM (VCDS)? That would give you an indication as to what the problem is..
Offline AlanD
  • MK5 2.0T 16v
« Reply #11 on: 05 May 2009, 10:15 »
^ Yeah, what he said. Would be the next step imo unless anyone else has any more bright ideas on here?
Offline Gene Hunt.
« Reply #12 on: 05 May 2009, 11:59 »
ok,found a cover to remove and got someone to turn engine over,camshaft is turning so the cam belt is not snapped :)
...............one bit of good news. :wink:
Candy White ED35.
Offline TomB
« Reply #13 on: 05 May 2009, 14:41 »
Very good news thats your cam belt is OK, my car is the same age and mileage and I was starting to worry!
VCDS is your best bet to getting it solved, other than that, have you checked if its getting spark and fuel?
Tom
MK5 Golf GTI in Tornado Red
Offline widget2k4
« Reply #14 on: 05 May 2009, 17:39 »
Got collected today and away to dealer,they reckon it's had some sort of power surge,ecu is fried and the coil packs,replaced them but it keeps blowing fuses so they will have it a few days :(
Offline DanoGTI
« Reply #15 on: 05 May 2009, 20:08 »
Hope it's covered under your warranty :)
At least you've hopefully got to the bottom of the problem :)
DAn
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline Rhyso
« Reply #16 on: 05 May 2009, 20:12 »
on an 05........unlikely  :sad:
lets hope the OP got an extended warranty!! Expensive day out otherwise!
Offline widget2k4
« Reply #17 on: 05 May 2009, 20:40 »
yeah its covered by warranty :)
just got the car and 1 year warranty thank god
Offline Rhyso
« Reply #18 on: 05 May 2009, 20:43 »
Result!!
new ECU is approx £700  :shocked: :shocked:
