Author Topic: Mk3 VR and 8v Subframes  (Read 3901 times)
Offline Mikester
  • Civic Type R
« on: 13 April 2009, 22:51 »
Will the VR Bolt straight to the subframe in my 8v gti? Or do they differ?
Same for drive shafts? is there a difference.
Mike
Re: Mk3 VR and 8v Subframes
« Reply #1 on: 13 April 2009, 23:20 »
I believe both are different.
Offline Mikester
  • Civic Type R
« Reply #2 on: 13 April 2009, 23:26 »
Hmmmm interesting. Thought the drive shafts might be, but not the sub frame.
« Reply #3 on: 13 April 2009, 23:33 »
Just checked vagcat, looks like the subframe is the same (1H0199315AA) however engine carrier is different.
VR6 : 1H0199200P
GTI : 1H0199200N
Shows lots of different part numbers for the drave shafts so I think they may be different.
« Reply #4 on: 13 April 2009, 23:36 »
Engine carrier is 1a.
Offline Mikester
  • Civic Type R
« Reply #5 on: 13 April 2009, 23:38 »
Cheers! Good info there.
Might have to change the carrier then. Got a mate breaking a VR, so i can swap it from there.
Thinking about fitting a solid mount too? thoughts?
Going to be collecting the parts for the conversion over the next few months, and fit it with a very very handy mate towards the end of summer.
Offline Mikester
  • Civic Type R
« Reply #6 on: 13 April 2009, 23:42 »
Fair enough, my mate just fitted one to his 8v mk2, rates them, but i have enough vibration as it is.
Might not be a good idea.
« Reply #7 on: 13 April 2009, 23:45 »
I would not use one but its your choice.
Offline danny_p
« Reply #8 on: 14 April 2009, 00:34 »
subframe is compatable iirc  frount crossmember diffrent
soild frount mounts are bad unless both rear mounts are good the bracket on the frount mount will snap at a later date
all the VW's have gone bar 1.
Offline Mikester
  • Civic Type R
« Reply #9 on: 14 April 2009, 19:19 »
So it should fit onto my 8v Subframe then? No need to find extra parts.
