Author Topic: Mk3 VR and 8v Subframes  (Read 3903 times)
Re: Mk3 VR and 8v Subframes
« Reply #10 on: 14 April 2009, 21:13 »
So it should fit onto my 8v Subframe then? No need to find extra parts.
Not sure I still think the engine carrier is different.
« Reply #11 on: 15 April 2009, 08:07 »
looking at vag-cat, rear subframes are the same on all MK3s.  The front subframer has 2 part numbers, one listed for all models including the VR6, and another seperate one for the VR6.  Doesnt say what the difference is:
(1) 1H0199200P - engine carrier with rubber mounting
/ ABF,AAA,ADZ, AEA,ADY,AEK, ABU,2E,AEP, AAC, diesel eng.: 1Y,AAZ,1Z
(1) 1H0199200N - engine carrier with rubber mounting
/ AAA
Offline Adam
« Reply #12 on: 15 April 2009, 10:38 »
The carrier is the same but the "Bonded rubber mounting" is different.
Down Hill From Here.
Offline Mikester
  • Civic Type R
« Reply #13 on: 15 April 2009, 18:57 »
So the differnece is just the mount?
« Reply #14 on: 16 April 2009, 09:36 »
like i say, according to etka there is a front subframe that is common to all models, and another that is VR specific but it doesnt say why.  so yes with an engine mount swap it'll fit your subframe unless there is something we missed. trouble is i cant get to etak/etos at the moment so I'm relying on vag-cat which is quite hard to make out some times
« Reply #15 on: 16 April 2009, 14:45 »
Aha! I finally got ETOS back up and I can now see the 1H0199200P is not listed for the VR6, 1H0199200N is the correct VR6 part number.
Cant tell you whats different about it though, might just be it has some kind of balance weight on it or something.  Looking at the ETKA diagram posted by 8v8v, you can see part #7 is only listed for the VR6, so this could be the reason for it.  You might be able to chuck the VR on a normal MK3 front engine mount though, but Id assume the limit stop is there to prevent the engine lifting up too much so its probably a good idea to use the correct front subframe.
Offline Mikester
  • Civic Type R
« Reply #16 on: 16 April 2009, 20:16 »
Cheers for all this info.
Will get hold of a subframe and VR engine mount. And if i need it, i need it i suppose. Just incase.
But will get new mounts obvs when i fit it.
Cheers again :D
