Author Topic: Clocks stopped working  (Read 4499 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re:Clocks stopped working
« Reply #10 on: 29 July 2004, 22:54 »
Thanks mate, will check it out, so if it's missing I can just get the cog as a replacement or the whole cable?
Offline Gambit
« Reply #11 on: 30 July 2004, 10:09 »
you just get a replacement cog/drive from VAG
Offline Deefadog
« Reply #12 on: 30 July 2004, 14:42 »
Ok, need urgent advice! got the engine side speedo out and cog is fine, but is the inside cable supposed to be loose, I mean I can pull it all out if I wanted.
If it is supposed to come out then maybe it has come lose on the clock side, if it is not suppose to pull through then I guess it has snapped.
And if it has snapped then do I replace the inside cable or the whole thing (outside aswell)
And what's the oil the cog is submerged in?
Thanks for any advice
Offline Gambit
« Reply #13 on: 30 July 2004, 15:01 »
if you can pull the inner cable out then it probably aint connected at the other end
there should be a bit of play in it as the cable has to bend round the back (or front) of the engine so naturally the inner cable has to be longer than the outer
might be easier just buy a complete (inner & outer) new cable and fit it. pretty simple job - and again not very expensive, bout ?20 inc vat
the little cog is submerged in the gearbox oil, which dont half smell bad!!
from GSF website
76145 SPEEDOMETER CABLE G2 16V 8/86  10/91  15.75
« Last Edit: 30 July 2004, 15:03 by Gambit »
Offline Deefadog
« Reply #14 on: 30 July 2004, 15:13 »
Thanks mate, just ordered one know will be in monday.
When putting the cog back in the oil does it slot into something? I am guessing so. How does it fit?
Offline Gambit
« Reply #15 on: 30 July 2004, 15:22 »
it just snaps onto the end of the cable, then you just put the cable into the hole and tighten  up with the wee nut, thats it
« Last Edit: 30 July 2004, 15:26 by Gambit »
Offline Deefadog
« Reply #16 on: 30 July 2004, 15:45 »
Aha, got in :) as the other end is loose when I put the cable back in I felt it slipping forward, think i got it now, i'll put the new one on Monday! Got to take the damn dash of again aghhhhhhh :)
and it does stink that gear oil, phew!
One more quick question if you don't mind, the needles on the clock have always been sticking, sort of stick at 2000 then jump to 3000 and so on, they sort of worked, all the rev counter also does it too, does that mean my clock are on the way out? or can I actually take the clock apart and grease it up somehow?
Thanks again mate
Offline Gambit
« Reply #17 on: 30 July 2004, 16:19 »
aye you can take them apart but it aint for the faint hearted.
if you make sure you put all the bits you take of in a sensible order(i.e. lay them out on a table) then it aint as hard
or take pics after certain stages so that you can look at it when your 'trying' to put it back together
Offline Deefadog
« Reply #18 on: 30 July 2004, 17:48 »
Sound a bit over me head :)
How much are new clocks? and what about the milage does it have to be recorded?
Offline Deefadog
« Reply #19 on: 31 July 2004, 10:21 »
Just got a price from the dealers - ?100 including VAT
Anyone else sell them?
