Author Topic: Just fitted Coilovers  (Read 14527 times)
Offline Adam
« on: 06 April 2009, 21:02 »
Hey I fitted my coilovers on Sunday, all is good except one worrying thing. When I turn there is a sort of clunk from what I can guess  is from the top mount area.
There is a small gap where the top mount plate is not sitting as it was when standards were on, normal? The top mounts turn slightly when I turn.
Have I done something wrong? I have a very long journey in the morning and am worrying.
Down Hill From Here.
Offline CraigDavid
Re: Just fitted Coilovers
« Reply #1 on: 06 April 2009, 21:31 »
Its Nothing Major To Worry About, I Had The Same Problem When I Fitted My Coilovers!!
I Assume The Noise Is Produced When The Front Wheels Are Rotated Slightly Or To Full Lock, Stationery Or In Motion?? – This Is Due To The Front Top Mounts Not Being Fitted Properly And The Coilover Is ‘Popping’ Out Of It Holding!!
Simple Flip The 2[Two] Rubber Top Mounts Over [Picture Below] And Re-Install And The Problem Should Be Fixed!!
Offline Adam
« Reply #2 on: 06 April 2009, 21:43 »
Spot on, will try this.
It is when it is stationary and at low-low speeds. Need to do this before I head off in the morning.
« Reply #3 on: 06 April 2009, 23:03 »
That is not mk3 top mounts and they will only go in 1 way so cannot see how you can turn them over.
Did you use new top mounts when you fitted the coilovers.
Offline Adam
« Reply #4 on: 06 April 2009, 23:06 »
Replaced with vr top mounts.
« Reply #5 on: 06 April 2009, 23:08 »
Well they only fit one way, your clonk could be normal due to the spring moving, I am not far away from you if it helps your welcome to pop over and I could have a look and listen.
Offline Adam
« Reply #6 on: 06 April 2009, 23:15 »
I'm off up north in the morning. Going to get the top mounts off and see for any wear but if it dosn't stop could u have a look for a few beer tokens?
Anything i should do? Is it normal for the top
Plate to sit high?
« Reply #7 on: 06 April 2009, 23:18 »
Plate to sit high?
This was my top plate with new vr top mounts, yes happy to look at it, just drop me a pm and I am sure we could sort something.
Offline Adam
« Reply #8 on: 06 April 2009, 23:30 »
will do cheers.
How much thread should there be on the top bolt? I have nothing both sides.
Offline Shady Pioneer
  • graphic designer.
« Reply #9 on: 06 April 2009, 23:34 »
My top plates look like wayned's picture, as do VRDans, not to that extent I think but there's a slight gap, I haven't ever worried about it but then again, I've never had any knocking since changing the top mounts to VR ones.
