Author Topic: Just fitted Coilovers  (Read 14492 times)
Offline Khare
  • The bear that khares
Re: Just fitted Coilovers
« Reply #10 on: 06 April 2009, 23:42 »
my top plates are liek wayned ones aswell.
« Reply #11 on: 06 April 2009, 23:48 »
I did ask the question on here and on ed38 about the gap and was told it is normal with coilovers, went straight through the mot no issues, car is still running the same gap now and has been like it for over a year so I think it is ok and nothing to worry about.
Offline Adam
« Reply #12 on: 06 April 2009, 23:52 »
Is it also normal for the top plate to move when you turn? Also the nut only just goes on with a mm or half a mm or thread on top.
Down Hill From Here.
« Reply #13 on: 06 April 2009, 23:57 »
No the top plate should not move, I think you may have put them together wrong.
If you check out this thread you will see the guide I did: http://www.golfgtiforum.co.uk/index.php?topic=68845.0 if you look at the picture of mine before I fitted you will see how I put it together.
Offline Shady Pioneer
  • graphic designer.
« Reply #14 on: 06 April 2009, 23:58 »
Just remember I have this pic of one of my top plates:
See what I mean about the gap, I'll check tomorrow to see if I have my plate move when turning it for you. Doesn't sound right mind you  :huh:
Offline 6sr
« Reply #15 on: 07 April 2009, 13:04 »
Are the VR6 mounts different to the early & late model GTI ones? Its just I've got both of these.
Thanks
Offline 6sr
« Reply #16 on: 07 April 2009, 13:12 »
Just to confirm if it is specifically the VR6 one thats needed, would it be:
Part number 45737 - STRUT TOP MOUNTING   G3 VR6 1/92 >12/97    Thats required?
« Reply #17 on: 07 April 2009, 13:50 »
I used and can recommend these: http://cgi.ebay.co.uk/VW-GOLF-MK3-GTI-VR6-CORRADO-SHOCK-TOP-MOUNT-KITS-C358_W0QQitemZ190297475021QQihZ009QQcategoryZ9889QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
  • graphic designer.
« Reply #18 on: 07 April 2009, 13:56 »
I got those based on wayned's recommendation and had no problems since the being on in Jan. :)
Offline 6sr
« Reply #19 on: 07 April 2009, 14:03 »
Thanks. I presume these are different to both the early and late model GTI versions?
