Author Topic: GTI rev limit 5k?  (Read 3790 times)
Offline javalin
GTI rev limit 5k?
« on: 06 April 2009, 18:14 »
Hello all,
Newby here - so hello!
Quick one - am looking at a 2l 8v GTI to upgrade my current mk3 1.8 8v!
On the listing the guy has put "Also still has original engine restriction at 5000rpm proven from ecu test that was replaced sept 2008 so the car has never been driven fast."
Did the GTI's have a rev limit of 5k?  He says its the AGG engine which Haynes say is a Simos 4S ECU
Cheers,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
Re: GTI rev limit 5k?
« Reply #1 on: 06 April 2009, 18:15 »
5k limit? that automatically kicks in when the the timing is out...
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 06 April 2009, 18:32 »
either timing or the ecu is in safe mode....(the timing is more common and easy to fix...just get the belt replaced at the same time)
Offline javalin
« Reply #3 on: 06 April 2009, 18:39 »
Thanks for the rapid replys chaps.
I suspect thats part of why the ECU was replaced.  Are they easy to get at on these?  I've done mine - was easy enough.
Any other fobiles of these engines?
Cheers,
James
Offline eightyeightmph
« Reply #4 on: 06 April 2009, 19:18 »
Cheers,
James
Only 115bhp?  :lipsrsealed:
Door? Coat? Gone!  :grin:
2016 GOLF GTD
  • Back in a Mk3...
« Reply #5 on: 06 April 2009, 19:45 »
these are the figures that matter (oh and your generous with the 115hp  :lipsrsealed:)
abf 133 lb-ft @ 4800rpm + 148bhp @ 6000rpm  :shocked:
agg 122 lb-ft @ 2600rpm + 113bhp @ 5400rpm  :cool:
see the tiny 11 lb-ft difference and thats 2200rpm lower (No thrashing needed for peak torque  :grin:)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #6 on: 06 April 2009, 19:49 »
Cheers,
James
Haha............. :evil:
« Reply #7 on: 06 April 2009, 20:04 »
Just playing devils advocate dude!!  :grin:
2016 GOLF GTD
Offline javalin
« Reply #8 on: 06 April 2009, 20:42 »
>Door? Coat? Gone!
good or bad?  Not sure of the meaning...?
Offline Cable
« Reply #9 on: 06 April 2009, 20:43 »
bad
