Author Topic: GTI rev limit 5k?  (Read 3778 times)
Offline Khare
  • The bear that khares
Re: GTI rev limit 5k?
« Reply #10 on: 06 April 2009, 20:54 »
Only 115bhp?  :lipsrsealed:
these are the figures that matter (oh and your generous with the 115hp  :lipsrsealed:)
abf 133 lb-ft @ 4800rpm + 148bhp @ 6000rpm  :shocked:
agg 122 lb-ft @ 2600rpm + 113bhp @ 5400rpm  :cool:
see the tiny 11 lb-ft difference and thats 2200rpm lower (No thrashing needed for peak torque  :grin:)
actually, my 8v has 135 lb-ft at 2800 all the way to 3800 rpm, and 116.6hp hp at 5400rpm. And that was in standard form  :evil:
Offline gti sa
  • Power from the GODS
« Reply #11 on: 10 April 2009, 21:35 »
yep timinig off.  you potentially need to have your cam belt changed as well as this will also throw it out.
Offline Neaty
« Reply #12 on: 10 April 2009, 21:53 »
either timing or the ecu is in safe mode....(the timing is more common and easy to fix...just get the belt replaced at the same time)
How do you take the ECU out of safe mode?
Offline boneybradley
  • Back in a Mk3...
« Reply #13 on: 11 April 2009, 00:06 »
either vag-com or disconnect the battery for 30 mins as this resets the factory values....but if the fault hasn't being cured it will kick back in!!
Offline lee_lee08
  • 1996 GTI 8v
« Reply #14 on: 12 April 2009, 10:46 »
mine revs all the way through 7k
I forgot I was driving my car and not an automatic courtesy car from work for some strange reason (put it down to being stoned) was joining the M3 from fleet service station and thought to myself why isnt it changing gear, as soon as I looked down at the rev counter the needle was proceeding through 6,500 rpm
F*CK better change gear then.
What would cause my rev limiter to stop working? or has some idiot before me been messing about?
Offline Adam
« Reply #15 on: 12 April 2009, 15:08 »
Good for you putting that on a public forum. twit :angry:
Down Hill From Here.
Offline AudiA8Quattro
« Reply #16 on: 12 April 2009, 16:17 »
Yes and the 16v unit will produce the same torque as the 8v at 2600rpm, how much torque will the 8v produce at 4800rpm? not alot probably  :grin:
