Author Topic: suppression? weird gear noise  (Read 5107 times)
Offline Simpson
  • one day il learn
« on: 05 March 2009, 22:35 »
as above recently just started hearing a whine of my gear change when i run through the gears, i know this is somethign to do with suppression but is it a problem with earth, stereo or something on the car possible x relief relay? oh car is fitted with sub and amped6 x 9s, and standard speakers, cheers  :smiley:
i must buy a new car!
Offline tommk3cab
Re: suppression? weird gear noise
« Reply #1 on: 05 March 2009, 22:37 »
I have never heard of this before.
do you mean it goes with acceleration ( if so this is pretty common) but making a noise when you change gear is a very strange one as you should not be making/breaking/changing any electrical connection.
Offline Adam
« Reply #2 on: 05 March 2009, 23:09 »
Is it a pioneer by any chance?  Alternator wine could be your problem.
Down Hill From Here.
Offline Simpson
  • one day il learn
« Reply #3 on: 06 March 2009, 19:31 »
sorry me not explainig properly yes it is on acceleration i apologise for confusion, any ideas? earths etc? cheers  :smiley:
Offline Adam
« Reply #4 on: 06 March 2009, 19:34 »
^^^^they are prone to the internal earth straps breaking and causing this. It happened to me.....it is fixable with a home bodge. I'v got a picture somewhere....Is the sound coming from the amped speakers? Are the std speakers amped?
« Last Edit: 06 March 2009, 19:36 by 8v8v »
Offline Dan34
  • VTEC Powerzzzz
« Reply #5 on: 06 March 2009, 19:36 »
i no this sounds odd but does it sound like a supercharger whine becuase that means you power cable is interfeering(sp) with your rcs\speaker cables.
Dan
Offline Adam
« Reply #6 on: 06 March 2009, 19:37 »
Called alternator wine, is your power cable on the same side as speaker wire/RCAs? It should be on the opp side.
Offline Simpson
  • one day il learn
« Reply #7 on: 07 March 2009, 20:17 »
yah its a bit like a supercharger sound, it was fine wehn i first fitted it, yes the sound is coming through 6 x 9s and sub i think and it kind of crackles when i take the facia off, guess il check wiring properly tomorrow, thanks
Offline tommk3cab
« Reply #8 on: 08 March 2009, 15:23 »
Dan
ever experienced this?
Its an urban myth, i.e, it never happens.
Offline Dan34
  • VTEC Powerzzzz
« Reply #9 on: 08 March 2009, 17:53 »
Dan
yes i had this in my mk3, i move the cables around and seemed to cure it
Dan
