Author Topic: Fitting of a genuine VW Satellite Navigation unit?  (Read 4489 times)
Offline Bstar
Hi, I am looking to buy and fit a VW MFD2 satellite navigation unit to my GTI Edition 30. This will replace the VW RCD300 BVX CD PLAYER unit, does anyone know if I need to buy Fascia Adaptors? or will it just replace the cd/stero with no problem? :huh: Thanks
Offline stealthwolf
Re: Fitting of a genuine VW Satellite Navigation unit?
« Reply #1 on: 01 March 2009, 21:18 »
Should be a straight swap in terms of size/dimensions but no idea whether you'd need extra harnesses to fit it.
Offline electric_cooper
« Reply #2 on: 01 March 2009, 22:31 »
no parts needed to fit it mate - just fitted one in my Dads R32
here is a quick guide
clip the top centre speaker/vent off (prise it out but careful not to break clips)
then one torx screw holding a plastic retainer in, then unclip
then 2 torx screws holding top of centre dash on
then 2 torx screws holding bottom surround on
once removed, this reveals 4 torx screws holding the unit in
very easy really, just take your time :)
Offline winrya
« Reply #3 on: 01 March 2009, 23:02 »
this is a good guide to taking the dash apart.  Its really easy, had to do it a couple of times now
http://www.golfgtiforum.co.uk/index.php?topic=40928.0
Offline ifti
« Reply #4 on: 02 March 2009, 10:36 »
There is also a video on youtube showing exactly how to take a dash apart....
Offline Teutonic_Tamer
« Reply #5 on: 02 March 2009, 13:11 »
But what about the GPS antenna - because on a car with just the RCD300 or RCD500, then VW didn't fit it?
I feel like a homo
Offline Jimp
« Reply #6 on: 02 March 2009, 14:43 »
Here's a good DIY of the sat nav install. He has the GPS antenna come out above the vent on top of the centre console.
http://www.vwaudiforum.co.uk/forum/showthread.php?t=21273
Not low enough mk5
Not on the road enough mk3
« Reply #7 on: 02 March 2009, 14:48 »
But you need to be a registered member of that site.  :rolleyes:
You would get far better info on the dedicated VW Navigation site - www.VWnavi.com - and you can view all their posts as a guest without needing to register.  :tongue:
I feel like a homo
Offline Spaced
« Reply #8 on: 02 March 2009, 15:01 »
You don't necessarily have to mount the antenna on top of the dash, i lodged mine inside the dash in a small void just to the top left of the unit, and have had no reception issues at all. But that may be down to the quality of the GPS antenna itself.
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline winrya
« Reply #9 on: 02 March 2009, 22:42 »
I fitted my antenna on the right hand side, under the grill on top of the air vents.  Usually sits on at least 9 sats
« Last Edit: 02 March 2009, 23:12 by winrya »
