Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240512 times)
Offline adaptorman
bit more tunnel modifying was needed this after
thought might as well get the propshaft in and make it a bit more leval/central
as it would have meant removeing lots of things to re fit it at a later stadge
Offline Khare
  • The bear that khares
nice one dude. This project is such a joy to read man! Hats off to you.
Offline adaptorman
nice one glad u like the idea ..
bit more upside welding 2day lol managed to get a hour to make and fit the propshaft 2day ,,,,
mount
couple of propshaft pics
Offline adaptorman
bit more modifying today , first decided to make the gearbox mount shorter for more road clearnace  , seems better , (nearly 2 inch removed)
more choping
then went radiator hunting as that needed modifying too
then started choping that too as i wanted a big core , for decent cooling
then removed the water pipes so they were on the same side of the rad
thought id have a go at radiator repairing lol
also added a bigger fan switch too
rough fit
then added a fan , i may add too depending on how it cools the engine
plenty of clearance now at the front
started with some pipe work seems to fit ok
 some quick brackets made and radiator done, i reckon it fills a hole lol
Offline jamie_pyrite
Incredible work!! I can't wait to see this thing when it's on the road  :smiley:
Offline Mr Blue
Offline adaptorman
cheers guys ,, bit more this after
all bolted back and wired fan up works a treat , also fitted a 75deg themostatat and fan sensor
next a start on the boost pipes ,looking a bit more like a engine
may get a bit more time 2moz to do a bit more
Offline adaptorman
more progress today
first needed to cut some lumps of stainless for intercooler , spot on with plazma cutter
quick pic of the intercooler
adjustable wastegate arrived too
then cut a lump out of the front , glad really as it was rotton inside
trail fit //it ull do
then welded the stainless and boxed it off
intercooler fitted
then added some boost hose and 4ply blue contectors along with some hefty clips
Offline adaptorman
i had to make the other as it was a tight spot
nicely fits
job done and bonett shuts too
Offline adaptorman
was looking under the bonett this after and thought i dont like these old plastic things ,, so thought chuff it ill make one lol
quick cut and weld and added a few pipes and a cap
then thought might as well add the washers on a sepete part so they will be hot water on the go
just have to make a quick bracket and another to top the washer bottle up /pipes poped on job done
