Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240509 times)
Offline adaptorman
not mutch to add ,thought id have a hour at makeing a fuel tank ,
first lump of stainless, should add some extra weight balance too
then tryed out my plazma cutter great piece of kit
then a quick buzz around with the welder lol
filled it with water to check my welds lol (leak free left it for a hour )
top and pipes to sort 2moz
a dam oil leak too ,, another prob to be sorted
height of the caddy /it will have to do
Offline shepgti
love the way youve got the side exhausts to sit. one of the best projects ive seen!
Offline adaptorman
nice one bud ,, ive another bracket to add  to lift it a tad more, nice comment cheers , carnt beat a bit of homemade stuff ,, seems to work , i reckon lol
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
This project is superb. Am loving the fact that if you've got something that doesn't quite work or doesn't fit, you make a new bit. And that pipework is a work of art...  :cool: :cool:
Keeping schtum. Mostly.
Offline adaptorman
carnt beat a bit of cut and chop ,,, lol ,, only home made stuff
bit of tank makeing 2day ...
more plazma cutting
quick zip around for fuel sensor
then a couple of tempory fits ,,nicely clears anti roll bar
make a few fasterners tomoz ready for fuel pipe work next
Offline mk1_dub
this project is amazing!
Offline adaptorman
thanks i think its just a bit of fun tbh ,lol
Offline mk2_abf
you should have your own business doing this
this guy is amazing cant wait to see it finished
Offline adaptorman
lol i wish ,,,, herance the home projects bit more here
well managed to sort a few bits this after , first made some fuel lines for the caddy
next deceied to chop the fuel flap out the boady
rare site lol, inside ,rot free
then went around the other side and chopped another hole out for the to refit the feul flap
not bad for a trail cut ,there was a slight gap so ,thought id add a filler rod , and welded up nicely
quick weld up
and grinded off
then oppss first thought id welded it wrong because its upside down ,must have got a bit carryed away , but i pref it to open this way lol ,little late now anyway
then a quick filler neck start on the pipe
Offline adaptorman
right 2day noticed the camber sticks out more on the fronts to the rears dose this wheel look ok to you guys as i think the botom of the wheel is towing out to mutch ?
as after i was looking at the rear they had way too mutch inwards camber , maybe ok for corners ,but not very good for scrubing tyres off , and what a dam stressfull trying to algin the wheel, after getting it a tad lower i carnt risk anymore , so altered all the arms and also insurted a smaller box and stick welded them for extra strengh
