Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240496 times)
Offline adaptorman
sh!t happernds , just at the wrong time , really ,, not worry ,,its only a vw  :wink:
so decied to remove all the underneath underseal , stressfull ,lol
which found a few more holes lol twiting vws lol
then decied to do all the under archers and got a bit carried away with the grinder and polished the coilover leg up ,, god knows what i was thinking lol
 makes things look rather tidyer then rusty steel and welds showing
same with the rears too
then welded the old truckman holes up and a tad a spray to stop rust until a later stage
then again i had to make a small spacer for the coilovers ,because with runing bigger mk4 cv jonts there were catching on the cv rubbers , so alterd the holes and made the spacer and welded it in ,so when heavy braking is needed the suspension leg carnt drop ,,and cause any problems , then gave it a clean up ,,
then as it was getting dark ish , thought id give the calipares a quick goinging over  lol
from this
to this
my paint then tbh honst ,,
Offline adaptorman
right had a few hours free so thought id start on the dash
first rip it out
then make a few strenghing bars
i wasnt sure were u mount the dash too above or below the window rubber
got best i could looks ok , but any idea i do with the side window covers as theres a gap ,
but its fitted ,and pref the black dash to grey ,, still was a bit tight on the ends and had to trim ends of the dash near the window corners to fit
another prob looks like the gearstick assembly will need moveing back a few inch too
so whos up on how the hell i rewire mk3 vr6 clocks and coloum storks into the mk1 wireing ,, as im stuck ,,,
Offline adaptorman
so 2day i neeeded a break an decided to find some cheep seats  after a quick clean i think they will do the job as they evern have runners so , easy to adapt
nice flat backs too ideal i reckon for a caddy
and i was going to fit a golf ball type gearknob but it dosent look right after bending the gearstick , so had to buy a nice 4 motion one to match the runing gear
Offline adaptorman
just when i thougfht i was getting somewere i deceied to rip the rear carparts out to find more rot ,,, didnt look bad until i gave it a few wacks with the hammer
there was more too below the seat mounts so thought chuff it , i rip it out
poped a plate on
then bent the gearstick to save catching the dash
quick fit of the carpet ,
 then realised like i idiot , i need a rear carpet , too lol ,ill make a mount for the gear surround to tidy that bit up too
Offline adaptorman
right not mutch to this after  , due to wheather
so ,  thought id modify the mk1 heater controls to fit the mk4 controls and they work a treat
then refitted it
and wired up the cig lighter lol (may come in for something)
and double checked all the dash wireing all seems fine
next i need a decent steering wheel i reckon
Offline adaptorman
tuck a risk and bought this with removeable boss, as i thought its come from a mk1 , should be ok for the caddy(i think)
and oil cooler arrived too ,, more things to fit lol
Offline adaptorman
right small start on the wishbones
first some solid round bar
then cut and weld in place
and bit of black spray poped on and refit
may help a bit i supose
Offline adaptorman
right thought id better start on the seat frame  again didnt want it ripping out of the floor so add some decent 2x2 box and rips the old seat mounts out
then made a decent strong box for the seat mount that shouldnt go any were soon ,and add some chassi strengh too ,
then add to make a few adjustments as im 6ft 5  and not a lot of room with the size of the dash in a caddy ,,
have to get more steel to finsh the other side lol
i was looking under the wear the old leaf springs used to be and the chassi and wasnt happy with it , so , it had to be ripped out ,
as ive now realiseing i need a stronger chassi
fits bang on inside the caddy chassi ,
carnt see that buggar going any were soon
Offline monzablue16v
Good progress :) In unrelated news I think this will stick around after you've had fun with it!
Offline adaptorman
well had a offer of 4k for it as it stands ,so im woundering wheather to sell it as it is ,, or carry on
did a bit 2day
not mutch due to coming down with the useal man flu ,,lol
so managed to finish off the welding ading more strengh to the chassi too
so decided im going to make a fuel tank on the rear as this will help with weight transfor as well/once ive finshed off the other side too
so ill not be needing a fuel flap anymore so ill weld that up as well
and nice clutch pot arrived too ,unsure if ill use it thow
