Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240550 times)
Offline Baylez8v
god i wish i could just do stuff like that when i was bored of looking at my sh!tty plastic bottles
Offline adaptorman
suprized what u can do with plastic bottles lol
not mutch just finished the header off ,and added a bit of vw washer cap ,,as im bisy with other stuff
also fitted all the water system pipeing but i carnt seem to find were the bottom heater matrix hose should be coupled to anyone know on mk4 24v engine?as ive not spare pipes so assumeing one may need a t piece fitting :banghead:
Offline adaptorman
had a water piping problem ,, now sorted thanks to ekta
Offline SoundillusioN
You're a feckin genius!!!! come round mine next time you're bored!
Offline adaptorman
lmao ,only a bit of cut chop and weld dosent leak and holds water sh should do
Offline tobz.
I've been following this thread from the start and I just have to say, absolutely awsome skills. It always amazes me that people with such skills think nothing of grabbing some bits of material and making everything from scratch.
I do however have a question (please don't take it as a criticism) but wasn't the idea at the start of this project to make a track toy??? I'm puzzled by the decision to replace manky looking lightweight plastic bottles with heavy stainless ones, likewise with the fuel tank there was a lot of heavy guage pipework going in there as with most other places.
Do you know how much the finished product is likely to weigh and will it still be nimble enough to throw round a track.
P.S. keep up the good work, I admire all the effort that is going into this beast.
You got any pics of your dad's split ?
Offline adaptorman
inice one pal , i have a few reasons really , i know usely poeple go for light weight vechicals , but basicly because of the mk1 golf is very flimsy on chassi so i had to beef everything up ,,and as i hasd a feew spare bits of steel i got a bit carried away tbh lol , but if u been or seen vides of these when the boost comes in ull need all the tracksion u can get , ie engine weight to make them tyres stick and rear weight (counter balance /for the back axle for rwd grip and weight /
Offline adaptorman
not mutch to add been bisy , but made a quick turbo sheild
Offline adaptorman
few bits of piping /one way valve for auxity pump
then i had a trail rev for 10 mins and it over heated reason was the single fan carnt cope , so added 2 bugger and all is well
caddys coming together at last
Offline adaptorman
god im fed up , this ecu has started playing up yet again , as im runing low inpendance injectors ,the ms unit has a built in curcit to make them run , as im sure its gone faulty due to major over fuel and dosent matter what i try to do ,its missing and smokeing like a deisal , so i may have to bypass this and run high inpendance ,,
then while tuning the spark and fuel maps , the engine started smoking badly , i thought the worst .but found the problem which was the turbo oil feed hole was too big (8mm ) which was bypassing the turbo seals so added this one
and also fitted a 90 elbow too , so thats sorted that problem out , no smoke , lol
then got the laptop back on the go to find , my air tempture not working so went hunting at the local scrap to find one , made a new therd and fitted and works a dam treat too ,,
(all these little things do help trust , just awaiting now to try a new ms part , if i get no luck il thow some high inpedance inejctors in , fingers crossed one or the other sorts the problem ,,
