Author Topic: TIP Fitted - With Pictures (page 2)!  (Read 5401 times)
Offline bobbarley
  • I'm kind of a big deal...
« on: 14 February 2009, 16:10 »
I agree with Rich, this is one of the hardest, most annoying things I've ever done!!!
I could NOT for the life of me connect the new pipe to the turbo, with that stupid pipe in the way.  I had to remove those allen key type screws for the coolant pipes, and got coolant EVERYWHERE!!
I got the new TIP on, and put everything back together again.  I can feel a huge difference, when I put my foot down it blasts through the rev's!!  Igf I floor it I get constant wheel spin too.
I don't know if the above is related to my problem though :( - http://www.golfgtiforum.co.uk/index.php?topic=106006.0
« Last Edit: 15 February 2009, 17:19 by bobbarley »
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: TIP Fitted
« Reply #1 on: 14 February 2009, 20:53 »
I've been doing mine today, too.  You're right.............................  That bottom part which slips (yeah, right) over the turbo was a right biatch!!  (Remember my AGU TIP has to go over the bigger KO3-S :angry:).
In the end, I sprayed it with some deodarant so it would slip on more easily (then it would evaporate later, you see ;)).  I'm not sure I 've tightened that bottom jubilee up properly, though, so I'm going to get back under tomorrow.
I took it for a run, & initial thoughts were excellent, though there was a couple of 'flat-spot' moments when I was up at 6k revs.  No fault codes before OR after fitment, though?! :undecided:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
Re: TIP Fitted
« Reply #2 on: 14 February 2009, 20:57 »
lol same as me i went back next day to make sue it was done up tight  :wink:
Yeah your was worse as you have the k03s
lots of swearing i hope  :undecided:
Offline bobbarley
Re: TIP Fitted
« Reply #3 on: 14 February 2009, 21:03 »
I don't know if it's just a placebo thing, but I swear it's more than a small difference it makes!
Re: TIP Fitted
« Reply #4 on: 15 February 2009, 00:28 »
5% performance, 95% placebo, IMO. A new sense has been awakened, Bob. ;)
You've now got more noise when u bury the throttle. ;)
Offline bobbarley
Re: TIP Fitted
« Reply #5 on: 15 February 2009, 00:30 »
I get more wheel spin too  :evil:
Re: TIP Fitted
« Reply #6 on: 15 February 2009, 07:36 »
Yes lots of f's, c's & b's, LOL!! :D  (& also, my knuckles look like they've done 12 rounds with a cheese grater, LOL. :D
That bottom jublee didn't look like it was on 'straight', either - but that could've just been me lying on my back??
Re: TIP Fitted
« Reply #7 on: 15 February 2009, 07:38 »
Well, that's no good - You won't be getting anywhere!!!
(Apart from a trip to Kwik Fit, LOL :D)
Re: TIP Fitted
« Reply #8 on: 15 February 2009, 07:39 »
 ps. Bob, I don't know why you had to remove the coolant line?? :huh:
Offline richw911
Re: TIP Fitted
« Reply #9 on: 15 February 2009, 14:00 »
PMSL @ cheese grater  :grin: :grin: :grin:
Yeah not east to see lying on ya back is it  :undecided:
