Author Topic: car wont turn over after replacing clutch cable  (Read 3204 times)
Offline sidecarphil
Re: car wont turn over after replacing clutch cable
« Reply #20 on: 05 February 2009, 21:07 »
ooh i've just re read your post
oops sorry
did the jump lead from engine to neg and still same so fitted a starter and it turns over :smiley:
plugs and leads are a start
Offline richard s
« Reply #21 on: 05 February 2009, 22:13 »
and as soon as i started reading your link i thought bollx as the rocker earth was a bit loose until i read further and saw that only sends clocks dodgy
i think its just being awkward because its been left sat covered in snow for almost a week
Offline richard s
« Reply #22 on: 07 February 2009, 19:36 »
put battery on today and it started straight away :smiley:and think i must ahve flooded it other day :embarassed:
Offline sidecarphil
« Reply #23 on: 07 February 2009, 19:50 »
tip top mate
sorry for scaring you so much  :grin: :grin:
Offline richard s
« Reply #24 on: 07 February 2009, 20:08 »
no probs mate all help is appreciated
i think i will treat it to new plugs leads rotor and dizzy cap after mot to avoid further winter embarresment
Offline Mr Blue
« Reply #25 on: 10 February 2009, 19:57 »
the small blue wire is to the alternator  :tongue:
i think you meant the chunky red/black trigger wire to the starter right? :)
Just disconnect this small blue wire at the connector block and the engine did not turn over. I noticed this when I changed the gearbox too.  :undecided:
« Reply #26 on: 11 February 2009, 11:28 »
hmm, you need to check your wiring! all this does is control the battery light on the dash...
unless its part of an alarm or something.
do you have a picture of it, i am intregued!
Offline Mr Blue
« Reply #27 on: 11 February 2009, 18:40 »
ez jonny.
That small blue wire that goes to the alternator. My alarm must has something to do with it then?
If i disconnect, the engine will not start. No starter motor. the fuel pump primes up and ignition comes on etc but no cranking
The wire was corroded at the connector block which sits around near the starter motor. I replaced it with a straight wire.
Been ok though but this is why i mentioned the blue wire. im guessing its a fault with my electrics :embarassed:
« Reply #28 on: 12 February 2009, 17:32 »
hm thats a new one on me! kinda handy though as without that wire the alternator wont charge the battery.  out of interest, does the battery light come on with the ignition and go out when the engine is running, both with the wire connected and disconnected?
Offline sidecarphil
« Reply #29 on: 12 February 2009, 17:37 »
i think it maybe something for the alarm ,
so it knows the engine is out or running
maybe some sort of "turbo timer" in the alarm :)
what alarm is it ?? who wired it in ??
