Author Topic: car wont turn over after replacing clutch cable  (Read 3201 times)
Re: car wont turn over after replacing clutch cable
« Reply #10 on: 03 February 2009, 10:02 »
the small blue wire is to the alternator  :tongue:
i think you meant the chunky red/black trigger wire to the starter right? :)
Offline richard s
« Reply #11 on: 04 February 2009, 19:44 »
grrr ive just been out and had another wiggle of the trigger wire and nothing so after that i left ign on and put a screwdriver from starter body to the nut on live feed and all i got was sparks so i think my starter is boned as im sure it should have turned over doing this
Offline sidecarphil
« Reply #12 on: 04 February 2009, 19:49 »
yeah if you connect the swiched contact wih the main one it should turn
THAT'S IF ITS GETTING AN EARTH
try adding a jump cable from the earth of the battery to the engine block
if this does nothing to help then change the starter
mine was a complete arse when i had my earth wire broken i thought it was the starter , rebuilt it and no better
Offline richard s
« Reply #13 on: 04 February 2009, 20:05 »
cheers mate i will be having another look tomorrow night and if earths are fine and the jump lead doesnt work looks like im laid in the snow and ice and fitting a starter  :sad:
Offline sidecarphil
« Reply #14 on: 04 February 2009, 20:19 »
the way i found my problem was
i used a mutlimeter set to ohms
connected to the battery earth to and the gear box
i had continuaty when the ign was off BUT as soon as the ign was put on boompf i got about 300 ohms of resistance
i stripped the cable off the car it looked ok on the outside but as a cut the insulation off it was absolutly knackered burned , green and really brittle
made a new one and perfect (after i bought a new ECU ) it got fried because of the earth path
Offline richard s
« Reply #15 on: 05 February 2009, 19:56 »
did the jump lead from engine to neg and still same so fitted a starter and it turns over :smiley: but will not fire now :cry:i have spark and fuel and battery has started to die so took it off and put it on charge for the night so will see tomorrow
im starting to get narked with this car now as on saturday clutch cable snapped bonnet catch bust and starter died and to top it off mot is due next saturday
does fate hate me or what :shocked:
Offline sidecarphil
« Reply #16 on: 05 February 2009, 20:11 »
now check how much fuel your getting into it
mine flooded it as soon as the ign was turned on
the ECU is fried fella
sorry to tell you this :(
i lost 20ltrs of fuel out of my sump after i found my problem GRRRRR
this is the link for my problem
http://www.golfgtiforum.co.uk/index.php?topic=90348.msg746826#msg746826
Offline richard s
« Reply #17 on: 05 February 2009, 20:26 »
it cant be ecu as you can pick them up quite cheap so it is going to be something like a single pole twin flange valve that costs £500 and needs £300 of specialist tools and a couple of professors at £1000 per hour to fit more than likely
Offline sidecarphil
« Reply #18 on: 05 February 2009, 20:32 »
make sure you get the one with the right numbers on it as they are differant
nah not expensave , mine was hard to get as the car had a cat from factory so needed the ECU with a lambda probe  :cry:
Offline richard s
« Reply #19 on: 05 February 2009, 20:48 »
might chuck a sickie tommorow and give it a looking at as im not convinced about ecu at moment as main earth was fine
im going to start with the free stuff like cleaning plugs different leads etc
