Author Topic: car wont turn over after replacing clutch cable  (Read 3197 times)
Offline richard s
« on: 01 February 2009, 19:23 »
on saturday morning my clutch cable snapped :cry: after an hour waiting for recovery truck :angry: with engine running he turned up towed me home and i then replaced cable after i went to work so car was stood for about 3 hours
after i replaced cable i went to start car and it wont turn over so i was wondering if their is anything i could have knocked that would stop the car from turning over
when i turn ignition on fuel pump primes then when i turn to start i can hear pump run and if key is held in start position pump stays running
im going to take a wire from battery possitive to the solenoid to check if immobiliser is off but after that im stuck
so all help greatly recieved
cheers
Offline DarnPB
  • Formerly Darnpistonbroke
Re: car wont turn over after replacing clutch cable
« Reply #1 on: 01 February 2009, 19:29 »
Did you disturb a bonding cable that earths the engine/gearbox to the chassis? I would look for this after checking the battery for voltage.
Offline richard s
« Reply #2 on: 01 February 2009, 20:11 »
dont think so but will check
check
Offline sidecarphil
« Reply #3 on: 01 February 2009, 20:22 »
or the little wire from the starter motor
 :undecided: :undecided:
Offline richard s
« Reply #4 on: 01 February 2009, 20:37 »
that is connected as it is only a spade connector due to using mk3 starter and been there before :grin:
Offline sidecarphil
« Reply #5 on: 01 February 2009, 20:39 »
tip top :)
i'd go with the earth wire mate
mine was screwed when i changed the clutch
fried my ECU :( :(
Offline richard s
« Reply #6 on: 01 February 2009, 20:47 »
if i put ignition on and run wire from to battery to starter and it turns over it will start correct
« Reply #7 on: 02 February 2009, 08:31 »
assuming the +ve and -ve connections  from battery are all ok yes :)
Offline richard s
« Reply #8 on: 02 February 2009, 20:23 »
everything was ok 3 hours before i fitted the cable
as for looking at it tonight nuts to that its far to cold and snowy
oh and ive got wifes car till thursday :cool:
Offline Mr Blue
« Reply #9 on: 02 February 2009, 20:44 »
my guess. that small blue starter motor wire has disconnected.
