Author Topic: Anni Gear Knob [s]Problem[/s] (Half) Sorted  (Read 7085 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« on: 22 January 2009, 10:55 »
I've been a bit of a plank, TBH.   :(  :rolleyes:
I researched the removal/fitting procedure & it all seemed pretty straight forward, so I went ahead & bought that Anni gear knob with no gaitor off eBay (you might've seen it??).  I assumed (like an idiot) that I'd simply be able to use my standard gaitor.  However the size of the plastic & metal retaining clips for the gaitor, along with the size of the 'stopper' on the knob itself (& the 'neck' of the gaitor leather), are a lot bigger than the Anni 'stopper', therefore, the gaitor clips just spin when placed onto the Anni knob.  (Please see below).
Anybody got any ideas, please?  Can I buy either the Anni clips &/or the gaitor sepreately?  (Even if i could just get the clips I think I could bodge the gaitor to fit).
Also, as (lack of) luck would have it, when I place the Anni knob on the shaft (it can only go on 1 way), the badge on the top is upside down.  Can this just be heated up, peeled off & re-glued back on??  :undecided:
TIA,
Ivor
« Last Edit: 24 January 2009, 21:30 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Re: Anni Gear Knob Problem
« Reply #1 on: 23 January 2009, 13:14 »
I've sorted out the 2nd prob - Just prized it off & spun it around!
Anybody got any suggestions on the gaitor & clip scenario??
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 23 January 2009, 13:25 »
This is just for holding the gaiter on the knob yeah? Big fat rubber washer might work.
w0ffle
« Reply #3 on: 23 January 2009, 13:44 »
p
« Last Edit: 18 November 2024, 19:23 by w0ffle »
Offline Stronz
  • Sold!
« Reply #4 on: 23 January 2009, 13:47 »
Could you not fold the top of the gator over (inside of itself) and create some sort of 'tie pull' to fasten it?
Hmm.... perhaps that isn't the clearest description I have ever given???!!!  :undecided:
« Reply #5 on: 23 January 2009, 13:49 »
Yeah, that's probably not a bad shout.
Initially, I was thinking of a hose clip/jubilee clip, but then it would have the screw bit sticking out which could potentially rip the leather.
Am going to pop into Halchavs later & see what kind of universal gaitors they've got.
ps  A zip/cable tie might do the trick, too. :afro:
« Reply #6 on: 23 January 2009, 13:51 »
Yes, that's how the OE one is held on, accept VW have had their own clip system fabricated. :)
Offline S7CYW
  • DUB
« Reply #7 on: 23 January 2009, 14:07 »
A small cable tie should do the trick.
w0ffle
« Reply #8 on: 23 January 2009, 14:11 »
p
« Reply #9 on: 23 January 2009, 18:21 »
Ok, thanks for all your help guys. I'll get some pics up when I've got it sorted. :-)  (fingers crossed).
