Author Topic: Anni Gear Knob [s]Problem[/s] (Half) Sorted  (Read 7088 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Anni Gear Knob Problem
« Reply #10 on: 24 January 2009, 15:39 »
Found an elastic band which seems to do the trick!
& this weeks "Pikey-Heath Robinson" award goes to.....................................................  Ivor Mk4 Turbo!!!  :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
« Reply #11 on: 24 January 2009, 15:41 »
Not perfect, but doesn't look TOO bad??  :undecided:
Offline Rhyso
« Reply #12 on: 24 January 2009, 15:42 »
looks ok mate - just remember you don't have a 6th gear  :tongue:
« Reply #13 on: 24 January 2009, 15:47 »
Yeah, I tried to get it into 6th, but it just doesn't want to go in. :(  Might have to send the knob back as faulty, now. :cry:  :D :laugh:
Offline nadlad
  • Building Surveyor MRICS
« Reply #14 on: 24 January 2009, 15:50 »
MUHAHAHAHAHAHAHHAHAHA
MUHAHAHAHAHAHAHAHAHAHA
thats funny  but ure gearknob looks like a swollen bell end lol :grin:
ivor u are a legend since i swapped my gaitor i been thinkign since how the f**k do i tighten that brass ring that i loosened to get it off and eureka u just shown me how to solve it..
whats size ring is that and where u get ot from?
« Last Edit: 24 January 2009, 15:53 by nadlad »
<<<Big Build Thread>>>
« Reply #15 on: 24 January 2009, 16:31 »
You best get to the doctors, Gonad, if you've swolen up like that before!!  :D
What do you mean the brass ring??  It's an elastic band!  :P  I couldn't use the metal & plastic retainer as it was too big for the Anni shaft!
Offline nadlad
« Reply #16 on: 24 January 2009, 17:03 »
lol u joker...........i meant the brass ring that used to hold the knob to the shaft where u have changed it to the a metal clip whats the clip called and size and where from?
« Reply #17 on: 24 January 2009, 18:03 »
Ah, I see.  It's a petrol pipe clip (15-17mm) - £1.55 for a twin pack from Halfrauds.  However, you shouldn't really need it, as even without that clip on, it should be quite hard to pull off.  (That's if you've lined it up properly AND pushed it down as far as you can - It should make a 'click' noise when it's on properly).
Offline T_J_G
« Reply #18 on: 24 January 2009, 19:31 »
Really tempted to buy the R-line 5 speed knob now VWSpeed have them!
« Reply #19 on: 24 January 2009, 20:20 »
Yeah, that's a smart looking GK. 8)
I'm quite a bit partial to that Lupo GTi one, myself.
