Author Topic: Help with lights  (Read 3863 times)
Offline Simon Mulley
Help with lights
« on: 21 January 2009, 11:01 »
I've bought a 4 lamp grill with inner spots,problem is tho that the leads on the back of the inner spots have 2 prongs on the end them but the the leads attached to the car have 3 holes,did they change the leads on a certain year or do I have the  wrong leads? Any help would be great.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Help with lights
« Reply #1 on: 21 January 2009, 12:23 »
Are you converting your car from a two lamp to a four lamp? :huh:
« Reply #2 on: 21 January 2009, 18:39 »
It is a GTi but had a 2 lamp grill fitted when I bought it,I assumed it would all just plug in.
Offline sidecarphil
« Reply #3 on: 21 January 2009, 19:04 »
well mine has a plug near the headlamps
just a 2 pin plug  :undecided:
Offline k4ith
« Reply #4 on: 21 January 2009, 20:37 »
my spots are just plug ins.
hijack
how do you remove and rebolt the spot lights btw?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline AdamMk2
  • Beautiful
« Reply #5 on: 21 January 2009, 21:52 »
by any chance are you trying to conect the other spare wires there??
Im sure I have inner spots then another spare lot?
Offline Jay
  • balding fat cvnt
« Reply #6 on: 21 January 2009, 22:07 »
Do you have the flogs plugged in where you should have the spots plugged in?
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #7 on: 21 January 2009, 22:13 »
Can you post pics of all plugs concerned, as these things should just plug in.....
Tom
Offline Ben Lessani
« Reply #8 on: 21 January 2009, 22:43 »
The two wire connector off the middle lamp connects to another wire which daisy chains off the H4 main beam connector.
I just rewired it when I uprated the loom
« Reply #9 on: 22 January 2009, 11:01 »
are the plugs you're trying to use rectangualr with like a rubber boot on?  If so you're probably looking at the electric headlight control motor plugs.  Some cars just dont have the spotlight plugs on, VAG sell liek adaptor plugs that go between the headlight plugs & the headlights.   If it was me though I'd get an uprated headlight loom which also runs the spots, theres plenty on ebay
