Author Topic: Help with lights  (Read 3864 times)
Offline Simon Mulley
Re: Help with lights
« Reply #10 on: 22 January 2009, 18:55 »
Cheers for the info fellas,I can only find the 3 hole plugs in the loom,they're light grey and have a rubber cover,if I get an uprated loom is it easy to fit yourself or is it a job for an auto electrician?
« Reply #11 on: 23 January 2009, 08:06 »
a good one is plug n playe, you hook up the + & - to the battery terminals, pop a trigger wire into the tip & main beam pins of the car plugs and then plug the loom into your lights.
« Reply #12 on: 23 January 2009, 18:36 »
I've solved the problem by buying an uprated loom so I should be able to see more than 4inches in front of me  :grin:
Offline maplesyrup
« Reply #13 on: 23 January 2009, 19:14 »
Uprated looms are the way to go its seems.
Are they an easy fit?
"when the going gets weird the weird turn pro"
« Reply #14 on: 24 January 2009, 19:00 »
According to E bay man they're  a 10 min job
Offline Ben Lessani
« Reply #15 on: 24 January 2009, 21:31 »
That's total lies!
5 minutes :laugh:
Offline skem55
« Reply #16 on: 25 January 2009, 19:46 »
uprated loom?
stuart
Offline Ben Lessani
« Reply #18 on: 25 January 2009, 21:18 »
As a sidenote, cleaning your headlights makes a masssssiiive difference too. People forget the obvious, at this time of year, they get super duper dirty.
Offline AdamMk2
  • Beautiful
« Reply #19 on: 25 January 2009, 21:23 »
Ive had that numerous times, especially when its salty onthe roads the dam heat burns the dirt to the glass!!!!
ahhhhhhhhhhhhhhh
