Author Topic: wierd noise  (Read 2635 times)
Offline golf-manic
wierd noise
« on: 20 January 2009, 18:05 »
hey guys,
i have noticed a wierd noise coming from the car and im not sure what it is. it sounds rumbly, but my mum seems to think it is a grinding noise :S
its from the front left, but thats all ive discovered.
ive just had a new wheel bearing and im really stuck what it can be.
cheers guys
Offline sidecarphil
Re: wierd noise
« Reply #1 on: 20 January 2009, 18:10 »
i'd have guessed at a wheel bearing
does it get louder with car speed or engine revs ??
jack the corner up and spin the wheel
you'll hear it if it is the wheel bearing
Offline golf-manic
Re: wierd noise
« Reply #2 on: 20 January 2009, 18:13 »
ive remembered ive missed some other info. out
when i turn left the noise disapears but when i turn right it stays the same.
i would have said it to be the wheel bearing but ive just had a brand new one fitted on staurday and the noise seems exactly the same, maybe a little bit quieter
Offline sidecarphil
Re: wierd noise
« Reply #3 on: 20 January 2009, 18:19 »
it is a left wheel bearing
if you turn left the weight of the car is off it so no noise
when you turn right the weight is on this the left side so noise :)
chect both front and rear as i have know noises to "travel" from front to rear LOL
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: wierd noise
« Reply #4 on: 20 January 2009, 18:27 »
check the discs, make sure there isn't a lip around the edge. this will cause a grinding noise
Offline DarnPB
  • Formerly Darnpistonbroke
Re: wierd noise
« Reply #5 on: 20 January 2009, 18:28 »
Is this rumbling noise complimented with a clicking noise too? Check the CV joint.
Offline golf-manic
Re: wierd noise
« Reply #6 on: 21 January 2009, 21:49 »
right an update.
definatly not wheel bearing, but it is related to the cv joint.
its the gearbox end joint, and there is abit of play in the joint. if this cures the problem ill informe you all
Offline OakeyDoak16v
Re: wierd noise
« Reply #7 on: 22 January 2009, 00:57 »
It's the other way round. The noise will stop when there is weight on it. :smiley:
Offline redhotjam
Re: wierd noise
« Reply #8 on: 22 January 2009, 16:36 »
Hate to say this but sounds like the gearbox diff bearing. I had same problem last year and after eliminating wheel bearings and cv's found lot of play on the left (n/s) driveshaft. Recon gearbox £400 and clutch £150. 5 hours to fit, could have done with a ramp and ten inch long fingers!!
O lny srmat poelpe can raed tihs. <br /><br />cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. The phaonmneal pweor of the hmuan mnid, aoccdrnig to a rscheearch at Cmabrigde Uinervtisy,
Offline sidecarphil
Re: wierd noise
« Reply #9 on: 22 January 2009, 16:41 »
Are you sure ???
