Author Topic: wierd noise  (Read 2636 times)
Offline redhotjam
Re: wierd noise
« Reply #10 on: 22 January 2009, 16:50 »
positive had the noise low grumbling sound front left disappears cornering
when i first noticed it changed wheel bearing still hear noise!
Changed cv still heared noise (cv makes grumbling noise when cornering, so didn't think it was that)
noticed play in d/shaft, so as my box had done 189k and had big 2nd gear clonk bought recon-box and new driveshafts. If in doubt I would change d/shaft and see if that sorts it!
O lny srmat poelpe can raed tihs. <br /><br />cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. The phaonmneal pweor of the hmuan mnid, aoccdrnig to a rscheearch at Cmabrigde Uinervtisy,
Offline golf-manic
Re: wierd noise
« Reply #11 on: 25 January 2009, 15:04 »
ive done the inner cv joint on the driveshaft and the outer cv, but still there.
its not as bad but its still the same noise.
im looking at getting a 2.0 bottom end this year and im hoping that the box will last 6 month at most
cheers anyway guys
Offline redhotjam
Re: wierd noise
« Reply #12 on: 26 January 2009, 16:49 »
Knew it was same as my problem gearbox hub bearings. One other piece of advice avoid techniclutch
I bought one of their fast road clutches of ebay and it failed after just 2000 miles. They didn't want to know when I contacted them. I don't mis-treat my car, so failire wasn't down to this just poor quality!!
