Author Topic: 10-15mpg whats wrong?  (Read 2285 times)
Offline pibeziako
« on: 11 June 2004, 20:10 »
I have a Golf GTI 1.8 turbo and the MPG currently is ranging form 10-15mpg.
Does any one have any ideas what could be wrong with it?
Offline topher
  • Administrator
  • fully functioning
Re:10-15mpg whats wrong?
« Reply #1 on: 11 June 2004, 20:18 »
Could be a number of things.. is it regularly serviced ? A totally sh1tted up air filter will cause you to burn more fuel. Quickest solution is to find someone with vagcom you can plug into to check for faults..  if you dont know anyone with vagcom then get yourself down the dealership or to a vag specialist.
Chris.
Offline Starry
  • http://planetweed.co.uk
« Reply #2 on: 11 June 2004, 21:25 »
if your only getting that mpg i would keep an eye on the car as i think someone must be steeling your fuel, or you have a hole in the tank. all joking aside as chris said its a job for vagcom or a mail stealer..
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
kniterider
« Reply #3 on: 12 June 2004, 20:11 »
sounds like a MAF sensor prob, these dont always show up on vagcom (but do some times!), you can remove the sensor from the air intake pipe but you need tamper proof torx driver to undo the special screws, then use and aerosol solvent cleaner to blast and crap off, make sure your air filter is clean also (best off fitting a new one) then give it a run and see what you get then, if still pant figure could mean the MAF sensor is cream crackered they cost around ?80-90 to replace, if your not sure on stuff though get it checked out to see if you have any fault codes showing, for example a dodgey temp sensor (for ecu) can make you ecu think the car is constantly cold so it will run rich hence the low mpg figure, hard to diagnose on here but give it a go cleaning your MAF sensor 1st (only ?3 ish for a solvent spray) then if your d.i.y.ing id try a new new temp sender at ?20 before you think about buying a new MAf sensor!!
Gaz 8)
