Author Topic: khare's mk3 GTI...16v!  (Read 246138 times)
Offline Khare
  • The bear that khares
Re: khare's mk3 GTI 8v
« Reply #300 on: 18 February 2010, 21:22 »
what's a leak down test??
shrocco
« Reply #301 on: 18 February 2010, 21:22 »
tell me what is the point of fitting a ABF to this car when you can go out and buy the same car.
x10000
plus will also be cheaper to insure
Offline Khare
« Reply #302 on: 18 February 2010, 21:22 »
x10000
No, and no.
Insuring the 16v was actually about £300 more expensive. Where as If I do the conversion, only have to put £140 on top.
Offline AudiA8Quattro
« Reply #303 on: 18 February 2010, 21:24 »
Fill each cylinder with compressed air, then see if it holds pressure.
I wouldn't perform a wet compression test, unless dry is bad or there is big difference between cylinders.
Yours looks spot on.
The point of a wet test is if the dry pressures are poor then wet will show if its valves or pistons.
shrocco
« Reply #304 on: 18 February 2010, 21:25 »
f**king nonsense.
Offline Khare
« Reply #305 on: 18 February 2010, 21:25 »
f**king nonsense.
I guess we will never know how insurance works.
What would be causing dramatic amounts of blow by though??
« Reply #306 on: 18 February 2010, 21:28 »
Check for blocked breather.
The best way to tell if the rings/valve guides seals are f**ked is a leak down test.
Offline Khare
« Reply #307 on: 18 February 2010, 21:29 »
have checked oil breather. I've also cleaned them out and it's fine, but there's a hell of a lot of pressure coming out straight from the crankcase.
« Reply #308 on: 18 February 2010, 21:34 »
I've already replied also on your thread in the mk3 section  :smiley:
« Reply #309 on: 18 February 2010, 23:08 »
x10000
No, and no.
Is that telling them everything, as I know you have not declared the cam change  :lipsrsealed:
