Golf mk2
ABF Lump
Topic: ABF Lump (Read 2093 times)
jacko16v
Here all the time
ABF Lump
11 December 2008, 17:04 »
Whats the going rate for an ABF lump, just picked a full engine with all bits bolted to it but no loom. Paid £70 for it.
Gonna strip and rebuild it, head work and then run it on weber 45's.
Does any one know if the kr ecu will be ok to get my spark from?
danny_p
Forum addict
Re: ABF Lump
11 December 2008, 17:42 »
meh it'll sort of work
all the VW's have gone bar 1.
jacko16v
Here all the time
Re: ABF Lump
12 December 2008, 08:04 »
Sort of work or will work? whats the best way to tackle it?
danny_p
Forum addict
Re: ABF Lump
12 December 2008, 11:08 »
really need mapable ignition with knock sensors.
never been inpressed with abf's on webbers they make about 170 - 175. but low throttel / rpm driveing isn't to nice and they are bloody thirsty. if you used bike carbs things would be a bit diffrent 40mm bike carbs will give more power and better part throttel driveing
jacko16v
Here all the time
Re: ABF Lump
12 December 2008, 14:12 »
So a set of bike carbs with a 40mm choke would be a better bet then. I presume i can make a inlet manifold from the old intake with out any major problems
Diamond Hell
Serious forum addict
Opinions я Us
Re: ABF Lump
12 December 2008, 16:29 »
You'll need to get a 'stub manifold' made up to take the inlet spacing from the 16V to the bike carbs, as this is almost inevitably going to be different. You *may* like to make a support bracket to go underneath the carbs which will hold them securely in place and ensure they work properly.
sidecarphil
Re: ABF Lump
Reply #6 on:
12 December 2008, 19:50 »
look up bogg brothers for a manifold to fit bike carb's , thay made one for me on my XR3 with a 2.0ltr zetec in it on R1 bike carb's
went like HELLLLLLLLLL
supped the fuel though :embarassed: :embarassed:
jacko16v
Here all the time
Re: ABF Lump
Reply #7 on:
12 December 2008, 21:01 »
Yeah seen bogg bros stuff before but aint upto paying there prices for a inlet manifold, have been told that i can cut a standard inlet and run off that with a bit or work for bike carbs, i'm not bothered about it being pretty, its only a track car.
sidecarphil
Re: ABF Lump
Reply #8 on:
12 December 2008, 21:12 »
£125 for a manifold
not expensave
from what i learned racing sidecar's is if you cut corners with cost's and stuff it will bite you in the ass with break down's
jacko16v
Here all the time
Re: ABF Lump
Reply #9 on:
12 December 2008, 21:18 »
Where do you get £125 frrom, when i spoke to them it was over £300
Golf mk2
ABF Lump
