Author Topic: Forge DV for Ed30  (Read 2522 times)
Offline SteveS
  • GTI ED30
Forge DV for Ed30
« on: 07 December 2008, 21:13 »
Should i bother? No i haven't got a remap YET, waiting for weather to clear up a bit :)
Wondering, Can i fit it myself? It seems simple enough, but then the guide goes into some "cap" and a4 info... which i assume i don't pay attention to as mine isn't an a4.. lol..
I also saw on vvortex that it was no better than oem...
Really just want ppls opinions as im in two minds of bothering....
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
WhiteGTI
Re: Forge DV for Ed30
« Reply #1 on: 07 December 2008, 21:19 »
What year is your car? Have you got a 'g' revision OEM diverter valve? Many argue that the problems associated with the stock DV have been solved by the 'g' version. I dont recall seeing any hardcore proof that this is the case though.
In all honesty, the forge is a much better product - the quality is second to none, and there will be no worries that it will fail. You are obviously worried that your stock valve will fail - as you are contemplating the forge. Buying the forge will therefore eliminate those worries.
Few peeps on here have fitted it themselves, im sure they will be more than willing to help you!  :smiley:
Offline SteveS
  • GTI ED30
« Reply #2 on: 07 December 2008, 21:29 »
i got it in july 07. how do i find out what rev it is?
would be handy if i could fit it myself, save the garage charge!
the OEM one can always be put back on (i.e to sell it stock) cant it?
SteveS
Offline keyser
  • They're only the band the beatles could've been.
« Reply #3 on: 07 December 2008, 23:09 »
After my remap my B version DV tore.  I have had the G version in 4 months now and everything is fine. Personally speaking I don't think the forge is necessary.  It cost me £30 and £30 for an independent to fit it.  It is called the cut off valve at the dealers.
MK5 GTI, manual, silver, dirty pipes.
Offline gazbutmk5gti
« Reply #4 on: 08 December 2008, 00:10 »
I think the K04 DV is more reliable than the K03 which is located in the hot zone bolted directly to the turbo, where as the K04's is located remotely at the front of the engine. The valve is made of plastic which doesn't lend itself to heat so the cooler the better :smiley:
Revo stg2+ & lots more
Offline SteveS
  • GTI ED30
« Reply #5 on: 08 December 2008, 00:20 »
so i should just stick with standard?
SteveS
« Reply #6 on: 08 December 2008, 13:11 »
I would until you have a problem, my ED30 did about 8000miles on the std DV remapped, and the S3 has done 5000 on the std DV mapped with no problems. Its up to you at the end of the day :smiley:
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 08 December 2008, 13:15 »
Steve, getting mine remapped next week with a DV being put on at the same time. Way I see if, if Im going to spend some money getting it mapped then might aswell fork out a bit more and get it put on to avoid the situation in the first place.
To my knowledge sooner or later it will go pop.
Offline Saint Steve
« Reply #8 on: 08 December 2008, 13:16 »
If it aint broke, dont try and fix it :wink:
Not worth it steve unless you modify ,which you havent yet.
Offline SteveS
  • GTI ED30
« Reply #9 on: 08 December 2008, 18:49 »
fine, ill have the 140 odd for something else... hummm
SteveS
