Author Topic: power advice  (Read 2368 times)
Offline andeep
power advice
« on: 07 December 2008, 16:21 »
hello, I am looking to get 2 pioneer ts-w3001D4 12" woofers installed into my mk5 gti.
They are both 1000W RMS, so I am going to be using a 2000W amp and 2 power caps.
Would I need to install another battery? Or uprate my alternator?
Thanks
Offline troublestarter
Re: power advice
« Reply #1 on: 07 December 2008, 18:02 »
i would definitely reccomend a better battery ditch the power caps better battery wins everytime
as for alernator you should be ok there i doubt your amp will pull that much current
what amp are you planning on using
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline andeep
Re: power advice
« Reply #2 on: 07 December 2008, 18:24 »
not too sure what amp im going to use, could you recommend one?
how many amps would the alternator be putting out? im not going to turn the amp up very often so that its pulling 2000w anyway.
what battery should i get?
Re: power advice
« Reply #3 on: 07 December 2008, 18:38 »
depending on the car the alternator could be either a 90 amp or 150 amp
amp wise something that is going to give 2000 rms is not going to be cheap
are your subs dual 4 ohm or dual 2
Offline andeep
Re: power advice
« Reply #4 on: 07 December 2008, 18:42 »
its this sub here: http://www.caraudiocentre.co.uk/product_m-pioneer-ts-w3001d4_p-22963.htm
Im thinking that there may not be any point in getting 2. May just go with the 1.
Re: power advice
« Reply #5 on: 07 December 2008, 19:12 »
if you want to go for just the one amp then this would be perfect 1000 rms at 2 ohm
http://www.awesomeautomotive.co.uk/catalog/product_info.php?cPath=3_15&products_id=214
as for a battery i would go for an optima yellow top £179.99 or a stinger sp170 around £200
Offline andeep
Re: power advice
« Reply #6 on: 07 December 2008, 19:38 »
that amp is a bit pricey, would this one be good? http://www.caraudiocentre.co.uk/product_m-jbl-gto-1201-1_p-21935.htm
also would I need that battery for just 1 subwoofer?
Re: power advice
« Reply #7 on: 07 December 2008, 23:43 »
that amp would be ok
probably be ok on the original battery with that
