Author Topic: Heavy Accelerator pedal  (Read 4667 times)
Offline gerlewis
« on: 04 December 2008, 13:40 »
Hi Guys,
Just bought a 2000 1.4 E,
The accelerator pedal is really stiff, is this common or are there any obvious/usual suspects?
I havent had a chance to look at it just yet, as its dark when I get home - something to sort on the weekend hopefully.
Cheers!
Ger
Offline dai-cymru
  • 1989 MK2 16V
Re: Heavy Accelerator pedal
« Reply #1 on: 04 December 2008, 13:50 »
i have a 2.0 and it's not stiff on mine
Offline ben1.8T
« Reply #2 on: 04 December 2008, 13:52 »
Check the throttle linkage could be corroded?  :huh:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline gerlewis
« Reply #3 on: 04 December 2008, 14:04 »
Thanks for the prompt replies, I will check the butterfly.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #4 on: 04 December 2008, 18:30 »
Also, get some grease on the throttle cable & pull it back forth to free up the movement.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline oliver07
  • golf gti T 200BHP
« Reply #5 on: 04 December 2008, 19:14 »
as above :grin:
Offline gerlewis
« Reply #6 on: 10 January 2009, 18:40 »
hi guys, here is the latest, I could REALLY do with your help on this one.
I took the car to a garage and the guy says there is a fault code with the Throlle Body, and its £695 for a new one from dealer. But he could do us a recon on the current one, which after labour is gonna be about £500 pounds.
Is this likely to be true, can this cause a stiff accelerator pedal? When I opened and shut the butterfly by hand t felt springy enough - ie like any other car Ive ever tried it on.
Does the throttle have some powered servo or something that could cause it to become stiff when driving?
Help!
Ger
Offline T_J_G
« Reply #7 on: 10 January 2009, 18:44 »
The throttle body will just need a clean out with carb cleaner! Not sure it would effect the pedal though.
Offline gerlewis
« Reply #8 on: 10 January 2009, 19:24 »
Well the pedal is defo stiff so its effected by something. Hmm, what to do?!
Maybe a second opinion at another garage is the key.
Can I eliminate the throttle body by disconnecting the cable and seeing if the pedal is still stiff, or some other bright idea.....
Ger
Offline gerlewis
« Reply #9 on: 10 January 2009, 19:29 »
ps. are these 1.4e cable or fly-by-wire type throttle?
