Author Topic: MFA MPG problem  (Read 2181 times)
Offline Bdub
MFA MPG problem
« on: 23 June 2003, 14:24 »
I have a Mk2 8v 1989 - the MFA reads 99.9 on mpg all the time. I have checked for leaks and all OK.
Does anyone know where the speed sensor is located?
Offline richandhazel
Re:MFA MPG problem
« Reply #1 on: 23 June 2003, 15:14 »
Offline Bdub
Re:MFA MPG problem
« Reply #2 on: 23 June 2003, 15:21 »
Thanks,
Sounds like a vacumn sensor fault as the average speed indication works fine.
Great site by the way - V useful
Offline ozegti
Re: MFA MPG problem
« Reply #3 on: 03 January 2009, 20:57 »
Does anyone know what the website said?
I have the same thing. MPH work, but MPG is 99.9mpg!
Offline Dan34
  • VTEC Powerzzzz
Re: MFA MPG problem
« Reply #4 on: 03 January 2009, 21:01 »
Hi, i think you need to take the clock out and see if the vacuum pipe that connects to the clock has come off or not if its come off thats your problem just put it back and should work fine.
Dan
Offline ozegti
Re: MFA MPG problem
« Reply #5 on: 03 January 2009, 21:17 »
I reconnected it, but it still says 99.9. Do I have to disconnect the battery and reset the whole thing?
Offline mk2 AL
Re: MFA MPG problem
« Reply #6 on: 03 January 2009, 21:29 »
Think you can reset it by taking the fuse out for 30 seconds i think i read on here somewhere.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: MFA MPG problem
« Reply #7 on: 03 January 2009, 21:42 »
There's a thing about this on VWVortex, if i can find it again ill post it, that site is like a black hole for re-finding things though!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Ben Lessani
Re: MFA MPG problem
« Reply #8 on: 03 January 2009, 23:03 »
Oldest dig ever, but I also want the answer.
rubberdubber
Re: MFA MPG problem
« Reply #9 on: 03 January 2009, 23:12 »
you can reset the mpg but holding the slider on the wiper stalk over to either side for a couple of seconds.  Should go back to: --- then bring up a reading as you start driving
