Author Topic: Low Washer Fluid - Warning Light on MK5 GTI  (Read 10739 times)
Offline vRStu
Re: Low Washer Fluid - Warning Light on MK5 GTI
« Reply #20 on: 02 December 2008, 16:31 »
You'll need a wire to the dash insert if you fit the sensor.  I remember a batch of Fabia's were made without the wire in place and it caused a nightmare for the service dept's.
Stu
Offline Rhyso
« Reply #21 on: 02 December 2008, 16:34 »
Hmm sensor can't cost that much... wonder if its an easy fit?
would have thought you'd need a new bottle and the sensor and wire it into the loom  :undecided:
Offline Komenda
« Reply #22 on: 02 December 2008, 16:46 »
Or how about the easiest option of all. When you pull the stalk and no water comes out, fill it up with some more. Hey presto cleany window.
Offline Rhyso
« Reply #23 on: 02 December 2008, 16:48 »
how are you going to do that at motorway speeds?  :huh:
 :laugh: :laugh: :laugh:
i don't really care as my MKIV has this fitted anyway  :smug: :grin: :grin: :grin:
Offline LaserBlue
« Reply #24 on: 02 December 2008, 16:52 »
i dont have the winter pack nor the highline display
i get warnings on washer fluid and all the rest
was only yesterday i got this
Offline Greenouse
« Reply #25 on: 02 December 2008, 16:56 »
Isn't that a coolant warning light?  :huh:
Offline vRStu
« Reply #26 on: 02 December 2008, 16:57 »
Hopefully you realised that isn't low washers  :rolleyes:
Do you have Xenon's?
Stu
Offline AlanD
  • MK5 2.0T 16v
« Reply #27 on: 02 December 2008, 17:31 »
I hope you realised that is a low coolant warning and topped it up with coolant before setting off on your way?
Offline LaserBlue
« Reply #28 on: 02 December 2008, 17:40 »
no xenons
yeah i just topped it up with water for now, will get some anti-freeze coolant from vw at the weekend mix it up a bit more.
and yes i knew it wasnt the washer fluid warning  :laugh:
Offline mad man gti
« Reply #29 on: 02 December 2008, 17:41 »
oh dear laserblue. mine has it and i have bi-xeonons and a highline com. when i orderd the car it said the highline com came as standerd on the car hope that helps.
