Author Topic: Low Washer Fluid - Warning Light on MK5 GTI  (Read 10745 times)
Offline Edition30
Re: Low Washer Fluid - Warning Light on MK5 GTI
« Reply #10 on: 02 December 2008, 14:02 »
Seems abit shocking that you have to purchase the winter pack to tell you to top the washer fluid up, my v v v vauxhall warned me. Bad on VW's part I say.  :angry:
sorry but my vaux looks far better than the mk5 gti, thats why i bought it  :wink: faster too  :grin:  :tongue:
July/08 Pearl Black Golf GTI Edition 30
Offline illyun
« Reply #11 on: 02 December 2008, 14:29 »
As correctly stated the low washer light is indeed part of the winter pack. However it can be programmed specificially by VagCom. So if you ask your dealer nicely the low washer light feature can be turned on on any MK5 Golf.
Really!  I didn't know that...  :smiley:  My new  My wife's new R32 has the winter pack and Xenons it has the washer by default and because it has leathers, they are heated anyway so that just leaves the washer light which I can sort myself.  :evil:  Thanks for that bit of info.
« Last Edit: 12 May 2009, 01:58 by illyun »
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline Rhyso
« Reply #12 on: 02 December 2008, 14:57 »
don't you require the sensor in the tank though like the MKIV?  surely they don't fit the sensor and not enable it  :undecided:
Offline Horney
« Reply #13 on: 02 December 2008, 15:08 »
Will the MKVI have a warning buzzer for if your low on credit on your phone, or your near your overdraft limit? How about a warning buzzer to tell you you are the laziest car owner in the universe?
Nick
Offline synnea
« Reply #14 on: 02 December 2008, 15:12 »
Well I had been told by someone on another forum that he had his done on his MK5 Golf. I am currently trying to locate the original source where I read it. It did indeed seem that the sensor was there already and i just had to be turned on electronically. In one way it makes sense I guess for all the cost of the sensor would likely be to simply bulk manufacture the washer tanks to all the same spec. That said I could be wrong as I have taken this guy's word for it. Maybe some of you with VagCom can have a look and see if the setting is in there.
« Last Edit: 02 December 2008, 15:14 by synnea »
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline GtiJames
« Reply #15 on: 02 December 2008, 15:14 »
its a bit poor if it can be switched on with vagcom, it just seems like vw conning people into buying the winter pack
it is a useful feature, was on my mini cooper before because the windscreen wash reservoir was smaller than a can of coke
Offline vRStu
« Reply #16 on: 02 December 2008, 15:29 »
I would think that if it's not already working, ie as part of the winter pack or Xenons then I very much doubt you'll have the sensor in place and thus won't be able to enable it.  Simple check is if you enable it and it immediately sounds/lights up then it isn't fitted.
Stu
Offline synnea
« Reply #17 on: 02 December 2008, 15:43 »
Just off the phone to a local dealer parts dept. Having checked ETKA he says the sensor is a seperate unit in the water tank so it seems what I thought may indeed be incorrect :( . The sevice guy was unavailable to tell me if all tanks come with the sensor fitted so he told me to check with the service dept. There was noone available at the time in service to see if they knew was the sensor fitted in all models.
Apologies for creating the excitment for those of you who wanted to enable it easily, as I had originally stated....seems I am wrong after all.
Offline illyun
« Reply #18 on: 02 December 2008, 16:21 »
Hmm sensor can't cost that much... wonder if its an easy fit?
Offline illyun
« Reply #19 on: 02 December 2008, 16:24 »
Re: The tax disc on your sig....  surely you can get done for that?  If not, then where can you get one from?   :grin: :grin: :grin:
