Author Topic: no clutch travel?  (Read 1396 times)
Offline GavG60
  • keep my credit cards away from me please :-(
no clutch travel?
« on: 07 June 2004, 10:51 »
my clutch engages when I lift the pedal about 2 inches off the floor, not much room to play with... when i put it in reverse, event with the pedal fully depressed there's sometimes a clunk.
Can I adjust this to get more play / travel?
Cheers for any responses
Gav :)
Offline davidhawkins_78
  • Valver Bad Boy
Re:no clutch travel?
« Reply #1 on: 07 June 2004, 10:55 »
Hello matey - me again :)
It all depends on 2 things:-
1. Has your car got an uprated clutch? If so, is it a ceramic paddle clutch or similar. This type of clutch has very little slip, and is almost ON or OFF. It has to be this way to cope with high levels of power.
2. Has the car got a manual or auto adjusting cable. Unless it's manual there's sod all you can do to move the bite point without changing the cable to a manual one.
Hope this helps ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline GavG60
« Reply #2 on: 07 June 2004, 10:58 »
errr....
1. don't know
2. don't know
3.  will go home and look later  ;D
Cheers dave  ;)
