Author Topic: Quick cable question..  (Read 977 times)
Offline Benrevs
« on: 30 November 2008, 19:30 »
Ive installed my battery in the boot and I need to run the power cables from it. Ive heard somewhere that you need 9.8mm od at 170A.  I have LOADS of cable from previous amp wiring kits and they are all 8mm, is this going to suffice? is there a higher load on main live cables as opposed to amp power cable?  Only asking as I am skint and cant afford £4 a metre of the stuff!! Ben
Josho
Re: Quick cable question..
« Reply #1 on: 30 November 2008, 19:34 »
What AWG is it? 4AWG might suffice but really, should be 0AWG. Suppose you could use two lengths of 4AWG.
Offline jacko16v
« Reply #2 on: 30 November 2008, 19:36 »
Just done this with my track car, cheapest way i found was to cut a new set of good quality jump leads and run a + & - and not the earth from the boot area.
Offline Benrevs
« Reply #3 on: 30 November 2008, 19:54 »
lol yea i did eye up the jump leads!!  Im thinking either chop up the leads as cant go wrong with rating there or go down the scrappers and steal the cabling from a beemer with the battery in the rear
Offline Ben Lessani
« Reply #4 on: 03 December 2008, 01:45 »
Is there any reason you've put your bat in the boot?
8mm cable is 0 awg - which is perfect for battery/alt wiring. It can tolerate about 245A which is well above what you'll need ;)
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 03 December 2008, 10:21 »
The boot is the right place to put the battery in a Golf - it re-distributes the weight backwards which will improve the balance of the car.
Offline Ben Lessani
« Reply #6 on: 04 December 2008, 09:09 »
So that's why my car is always toppling over!
