Author Topic: drums to disc  (Read 1679 times)
Offline big--jayt
Re: drums to disc
« Reply #10 on: 28 November 2008, 15:25 »
how easy are they to take off and change ? also if i took the one off the car would i be able to see if its bent just by looking
<br />theres only one way to roll and thats in a vdub
Re: drums to disc
« Reply #11 on: 28 November 2008, 19:07 »
biggest headache is the caliper carrier bolts, if they come out ok then its relatively straightforward.  Disc off, dust plute off, some bolts and off comes the stubby!  I'd take one off the 5 stud beam and hold it up next to the one on the car, should be obvious if yours is bent :)
Offline big--jayt
Re: drums to disc
« Reply #12 on: 28 November 2008, 22:34 »
i dont ave another one to check it with so how could i tell
Re: drums to disc
« Reply #13 on: 29 November 2008, 10:32 »
I thought you had a 5 stud GTI beam? Nick one off that, or is the beam bare?
Offline big--jayt
Re: drums to disc
« Reply #14 on: 29 November 2008, 15:23 »
i dont have 5 stud beam ive have been offered one thats all by bloke in colchester so have nothing to compare it to
Re: drums to disc
« Reply #15 on: 30 November 2008, 16:48 »
ah i see! if you have the rear wheels off and compare the angle of the disc to the beam i recon you should be able to spot if the beam or the stub is bent :)
Offline big--jayt
Re: drums to disc
« Reply #16 on: 30 November 2008, 22:12 »
cool ill give it a go if i get chance this wknd coming
