Author Topic: drums to disc  (Read 1674 times)
Offline big--jayt
drums to disc
« on: 26 November 2008, 19:07 »
How easy is it to change from drum breaks to disc on a mk2 gti as my axle is bent and cant seem to find one near me and have been offered one with drums can anyone help or if anyone has a gti rear beam near colchester pm me many thanks
<br />theres only one way to roll and thats in a vdub
Offline nealey
Re: drums to disc
« Reply #1 on: 26 November 2008, 19:37 »
You will need handbrake cables and to repipe the solid lines to get rid of the compensator
Tbh its a bit of a downstep going to a non gti rear axle as you will lose the rear anti roll bar
Offline Jay
  • balding fat cvnt
Re: drums to disc
« Reply #2 on: 26 November 2008, 19:56 »
Not all GTi's had discs on the rear iirc, so it could be an early GTi rear beam, while it's not attached to anything surely he could have an ARB fitted/welded on.
Offline troublestarter
Re: drums to disc
« Reply #3 on: 26 November 2008, 20:05 »
jay t
i forgot to mention i also have a mk3 gti rear beam but it is 5 stud
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline richard s
Re: drums to disc
« Reply #4 on: 26 November 2008, 20:49 »
phone vw and see if they list more than one part number and if they only have one part number evrything should swap over
Offline Mew
Re: drums to disc
« Reply #5 on: 26 November 2008, 21:33 »
Meh, mine's about as early as it gets and it has rear discs. They weren't an option either so i'm not convinced about the "not all gti's have rear discs" that i've read aswell tbh.  :smiley:
Re: drums to disc
« Reply #6 on: 27 November 2008, 09:49 »
the compensator is fine to leave in, 1.8 carb models with the 9" servo had them.  Pretty much a bolt on swap, you could convert it to discs even by swapping over the stub axles etc.
Are you sure its the actual beam thats bent and not one of the stub axles though?
The 5 stud GTI beam will swap straight on too, just fit 4 stud discs :)
Offline big--jayt
Re: drums to disc
« Reply #7 on: 27 November 2008, 20:12 »
[/quote] im not sure as the rear wheel sits out at the top it has hit a curb not sure how fast it was going as it was done by last owner how would i be able to tell if its the axle or sub axle ?
Offline nealey
Re: drums to disc
« Reply #8 on: 27 November 2008, 20:26 »
All gtis have discs on the back from launch, i have the sales brochures to prove it
You are thinking of mk1 gtis, they all had drums on the back
Re: drums to disc
« Reply #9 on: 28 November 2008, 10:36 »
if you took the wheel of and did some measurements then repeat for the other side, i recon you should be able to spot if its stubby or beam?  Could always whip the stub off the mk3 axle & swap over, if the carrier bolts dont round out the job shouldnt take too long?
