Author Topic: Which is best stereo single din fascia adapter for the Mk5?  (Read 5730 times)
Offline Emeye
I've seen a few different ones for sale on-line, but it's hard to judge the quality.:huh:
Ideally I'd like one that has a tray which can be located in either the top or bottom slot, but I want one that matches the VW plastic as well as possible.
Which one would you recommend, or buy?
Cheers. :)
Offline Incitatus
Re: Which is best stereo single din fascia adapter for the Mk5?
« Reply #1 on: 25 November 2008, 06:57 »
VW sell their own that matches perfectly (it should do!). The part number is 1K0857058A1QB.
Offline Hurdy
« Reply #2 on: 25 November 2008, 09:17 »
Yes, the VW one is the best match I've seen so far for single din applications (or two single dins together as you are going for emeye!). I personally haven't seen a VW with 2 single din units using the double din slot :undecided:
Seat Leon Cupra Black 290 DSG
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 25 November 2008, 09:37 »
Got mine from VW as said and its a perfect fit and colour match. Only £20 aswell.
Offline Emeye
« Reply #4 on: 26 November 2008, 00:10 »
Cheers,
Will this one take 2 single din units or is the cubby permanent?
Cheers. :)
Offline AlanD
  • MK5 2.0T 16v
« Reply #5 on: 26 November 2008, 12:11 »
From memory the cubby is permanent. Im poping out for a fag in a sec so will check then and report back in 30 minutes or so.
Offline SteveS
  • GTI ED30
« Reply #6 on: 26 November 2008, 12:16 »
i got one from VW and its a blaupant (spelling) one... its darker than the dash!! they said thats the one they get...
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 26 November 2008, 12:24 »
MY VW one is a perfect match the dash and I can confrim that you CAN NOT put 2 single dins in it.
Offline SteveS
  • GTI ED30
« Reply #8 on: 26 November 2008, 12:29 »
hum my bottom din has a tray which could come out for a 2nd din.. odd
SteveS
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 26 November 2008, 13:37 »
Sounds as if we have diffrent ones  :undecided:
Is a one peice mould which cant be removed. Its just cubby whole and single din unit whole.
