Author Topic: Ignition timing  (Read 902 times)
Offline maximous
Ignition timing
« on: 24 November 2008, 11:51 »
need a timing belt cover to time the old girl up properly anyone got a spare?
It's a Mk2 16v
Max
Offline Conker
Re: Ignition timing
« Reply #1 on: 24 November 2008, 20:32 »
Am I right in thinking you don't have to have the cover to time the lower sprocket - you can use the marks on the flywheel (prob more accurate too!!).
Offline maximous
Re: Ignition timing
« Reply #2 on: 25 November 2008, 08:52 »
have an after market flywheel with no marks on it what so ever; so am thinking if i get the cam belt cases with the timing mark on it i can align it all up, dab my flywheel with tipex and go from there, not the best solution but better than doing it by ear
Offline mattkh
Re: Ignition timing
« Reply #3 on: 25 November 2008, 10:16 »
Hi
I prefer the long-screw-driver-down-the-plug-hole method.
Re: Ignition timing
« Reply #4 on: 25 November 2008, 10:20 »
good enough to get you close, but due to the dwell angle on the piston its not the best solution.
