Author Topic: MK2 16v Suspension ideas  (Read 11078 times)
Offline drapergti
« on: 24 November 2008, 07:38 »
Hi everyone, could you tell me what you have done/would advise in terms of suspension upgrades?
I want to keep the car as original as possible. So would only want a small drop if absolutely necessary. Should I also change the bushes to upgraded ones?
Had an 8v a long time ago and made a mistake in getting some rather harsh shocks and springs and it spoilt the car for day to day driving so want to keep it comfortable.
Would it be better to just replace like for like?
I would welcome you thoughts and inspiration!
Thanks
Stuart
Offline Diamond Hell
  • Opinions я Us
Re: MK2 16v Suspension ideas
« Reply #1 on: 24 November 2008, 07:58 »
-40mm springs on fresh standard gas dampers and new standard bushes and mounts all round.
This will probably give you the best ride/handling compromise, if comfort is a factor.
Offline drapergti
« Reply #2 on: 24 November 2008, 08:24 »
Thanks for this, do you have any spring manufacture recomendations?
Offline Nate187
« Reply #3 on: 24 November 2008, 09:00 »
Boge gas dampers and eibach -40mm springs sound your best bet.
Its not a Gti without the stripe
VeeDubGTI16v
« Reply #4 on: 24 November 2008, 09:12 »
id suggest koni sports dampers and eibach springs, its a great setup
putting lowering springs on standard dampers is a stupid idea, you might as well cut the original springs!
Offline MarkS
« Reply #5 on: 24 November 2008, 09:29 »
My vote would go for koni dampers and eibach springs
They're fantastic :afro:
Not overly cheap though  :undecided:
But I'd say definately worth it :)
Offline Mannings
« Reply #6 on: 24 November 2008, 10:51 »
I run Koni adjustable shocks with eibach -60mm springs. Prob too low for your requirements but handling is top draw.
Also know this might sound a bit obvious but a good set of tyres (i've got Toyo Proxes T1S's) and have the tracking correctly set improve the set up incredibly.
However best handling golf i driven was running fully adjustable gas coilovers, was a tough ride but handling was different levels, looking about £300 minimum though.
My suggestion, -35/-40 springs and a decent set of adjustable dampers, good tyres, correct tracking and you'll have a B road legend ready to roll.
Offline sidecarphil
« Reply #7 on: 24 November 2008, 10:57 »
what about the hot tuning coilover deal ??
adjustability man , that's the way forward
Offline Organisys
  • Old and Slow...
« Reply #8 on: 24 November 2008, 12:21 »
Eibach designed to work fine with OEM dampers.
Offline Organisys
  • Old and Slow...
« Reply #9 on: 24 November 2008, 12:22 »
...and sh1t ride quality, he said he wanted to keep the car original, so he isn't going to do a huge drop.
