Author Topic: MK2 16v Suspension ideas  (Read 11079 times)
Offline Nate187
Re: MK2 16v Suspension ideas
« Reply #10 on: 24 November 2008, 14:23 »
id suggest koni sports dampers and eibach springs, its a great setup
putting lowering springs on standard dampers is a stupid idea, you might as well cut the original springs!
Eibach designed to work fine with OEM dampers.
Yep and great if your on a budget, i paid £90 for eibach springs & boge gas dampers off here  :smiley:
Its not a Gti without the stripe
Offline paultownsend
« Reply #11 on: 24 November 2008, 15:10 »
good bargain that! hows the exhaust?
Offline sidecarphil
« Reply #12 on: 24 November 2008, 16:55 »
are the hot tuning coilovers really harsh then ???
cos i have asked santa for them  :grin: :grin:
« Last Edit: 24 November 2008, 16:59 by sidecarphil »
Offline Nate187
« Reply #13 on: 24 November 2008, 17:02 »
LOL cool mate, although the car is still off the road. Ive just finished fitting new brake pipes/ bias valve and adding new fluid. Getting new tyres fitted tomorrow then she's ready for an MOT whooooop! Its been a long 5 months, phew.
Offline monzablue16v
« Reply #14 on: 24 November 2008, 18:00 »
No not at all unless your slammed to the deck and even then it's not that bad I had cheap springs on standard shocks and they were much worse.
Offline drapergti
« Reply #15 on: 24 November 2008, 19:00 »
Crikey, amazing response thanks all. I will need to check the prices but think that the Koni/Eibach route to be the best compromise. Do I need to fit uprated top mounts or performance bushes? The car is totally standard and on the original shocks so wondered if this would be a good idea? Also (yes lots of questions and do not want to take the p) but would a strut brace be a good idea aswell?
Offline AudiA8Quattro
« Reply #16 on: 24 November 2008, 19:25 »
I wouldn't drop the car by more than 25/30mm, well not if you drive near speed humps  :laugh:
Offline drapergti
« Reply #17 on: 24 November 2008, 19:34 »
Loads of speed humps, any ideas if I go for a -25 drop?
« Reply #18 on: 24 November 2008, 19:38 »
Eibach springs and koni dampers.
Offline drapergti
« Reply #19 on: 24 November 2008, 19:47 »
I'm guessing that was obvious to everyone else but me! LOL thanks for the advice all I will check out the prices. Cheers!
