Author Topic: 16v to vr6 exhaust  (Read 1212 times)
Offline ace
16v to vr6 exhaust
« on: 21 November 2008, 09:28 »
im planning on swapping the exhaust of my bro-in-laws 16v onto his vr6 tomorrow, just needed to make sure that it will fit?????
its from the cat back. pretty sure that it should fit, but just need confirming of this.
thanks
Re: 16v to vr6 exhaust
« Reply #1 on: 21 November 2008, 10:05 »
I am sure they are the same
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 21 November 2008, 12:06 »
should be same fitting!! (as from the factory they were identical from cat back) but knowing how parts places mix and match when replacing things just check the bore from the cat to be sure
Offline ace
« Reply #3 on: 21 November 2008, 12:17 »
yeah i thought that was the case, it should hopefully be fine, vr has got a standard sytem on, so fingers crossed it will be fine.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 21 November 2008, 12:23 »
It should fit, but i get the feeling (might be wrong)  that the later 16v is the same bore as the VR6 but the pre 95 is slightly smaller.  Might be worth checking if its an early model as you will need an adapter if that is the case.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline ace
« Reply #5 on: 21 November 2008, 12:51 »
the 16v is a 96 and the vr is 97 so both are the later models, hopefully should be a case of taking one of and fitting on the other.
Offline Len
« Reply #6 on: 21 November 2008, 13:21 »
Straight swap mate!
www.sas.org.uk
www.the-ace.org.uk
