Author Topic: A word to the wise for Alpine iPod HUs!  (Read 12607 times)
Offline Shady Pioneer
  • graphic designer.
Re: A word to the wise for Alpine iPod HUs!
« Reply #20 on: 04 December 2008, 18:20 »
Which one did you get matey?
Offline eightyeightmph
« Reply #21 on: 04 December 2008, 19:13 »
Alpine CDE-9881R :afro:
....it lights up green to match the interior! ;)
All hooked up & working, iPod doesn't seem to charge & as said doesn't turn off so I'll email Alpine.
Just the speakers to sort now but sounds a ton better than my old 4x45 Xplode! :D
2016 GOLF GTD
  • graphic designer.
« Reply #22 on: 04 December 2008, 23:23 »
You got the model up from mine then? I got the 9880R...what's new in yours? lol! Do yo like it?
And was it the new nano you got yeah?
« Reply #23 on: 05 December 2008, 08:43 »
In short, YES! Sounds brilliant, can't wait to get better speakers. Not sure what it does differently to yours, to be honest the only reason I went for this one was I found it cheap! ;)
Yea, 4th gen nano, I've emailed alpine so hopefully they'll sort it out for me. :D
2016 GOLF GTD
Offline AlexKid
  • Living well is the best revenge.
« Reply #24 on: 05 December 2008, 16:31 »
I want one of these but before I go ahead how can I be 100% sure my 4GB Nano is fully compatible?
1999 MkIV Golf 2.0 8v
  • graphic designer.
« Reply #25 on: 05 December 2008, 18:01 »
No it's not, it'll only play, it won't charge or stop when you turn the engine off / HU off.
It's not the HUs fault, it's Apples fault, they've done something to the dock connector at the bottom and removed some pins which the Alpine, and most other HUs use to charge it up.
Offline AlexKid
« Reply #26 on: 05 December 2008, 20:27 »
Seems pointless getting it then?
Offline AlexKid
« Reply #27 on: 05 December 2008, 20:29 »
What iPod's will work?
  • graphic designer.
« Reply #28 on: 06 December 2008, 00:19 »
It's not pointless, Alpine are working on a lead that can charge the new 4th gen nano, it's Apple's fault, because it does mean almost all stuff that works with an iPod dock connector won't work properly unless it's made specifically for the 4th gen nano. Your nano will still play, just won't charge, so it's life will be just like what would use it like if you used it walking around.
Literally all other iPod works like they are meant too.
I had my mates 30GB video on it tonight, I've had an iPod Touch on it, and a 1st and 2nd gen nano, also the latest 120GB Classic works as that's what I'm using on it now.
Offline AlexKid
« Reply #29 on: 06 December 2008, 09:17 »
Might be worth holding fire though until they issue a new lead.
