Author Topic: camber adjustment?  (Read 4796 times)
Offline no1nutter
camber adjustment?
« on: 18 November 2008, 17:55 »
is it possible to adjust the camber on mk3 gti?
Offline boneybradley
  • Back in a Mk3...
Re: camber adjustment?
« Reply #1 on: 18 November 2008, 17:57 »
front camber yes... most good trye places can sort it for around £60-80
Offline no1nutter
« Reply #2 on: 18 November 2008, 18:01 »
how do they do this? i was under the impression that it was pre determined and only a bit of butchery such as elomngating holes was the only way?
Offline Horney
« Reply #3 on: 18 November 2008, 18:08 »
There is a degree (get it!) of play in the front hub set up. If you want to go mad then yes you need to start effing about.
nick
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #4 on: 18 November 2008, 18:19 »
i was under the impression vw can supply slightly thinner lower strut bolts to give a couple more degrees of adjustment?  :undecided:
Offline AudiA8Quattro
« Reply #5 on: 18 November 2008, 18:39 »
Mk3's are unjusted strut to hub. You shouldn't need thinner bolts, unless you want to go extreme.
Offline don_231
« Reply #6 on: 18 November 2008, 19:52 »
if you want loads of adjustment get hold of a set of passat struts and swap your springs over. they have rediculious amounts of adjustment as i found out at the weekend when i did said thing
just make sure you swap your springs over unless your after the 4x4 look
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #7 on: 18 November 2008, 20:07 »
You can get a fair amount of adjustment on the front as they are. More than you will need usually.
jamie16v
« Reply #8 on: 18 November 2008, 20:41 »
sorry to hi-jack, but is there a DIY method of adjusting the camber correctly?.  as in getting the right anlges, if so,  how?.
Offline no1nutter
« Reply #9 on: 18 November 2008, 21:30 »
ok, so what would have affected my camber in the 1st place, aftermarket shocks/wheels?
