Author Topic: camber adjustment?  (Read 4801 times)
Offline Ads
  • 8V RULES BABY!
Re: camber adjustment?
« Reply #20 on: 19 November 2008, 19:26 »
If you have had the shocks off you camber will be affected.Your meant to mark the bolts & Hub before removing them, otherwise when come to do the bolts up again you will set a different camber angle.
Offline Ess_Three
« Reply #21 on: 19 November 2008, 23:43 »
Standard Mk3 Golf front camber should be between -0.20 and -1.00 degree.
Running the wrong camber will wear your tyres down pretty quickly usually on the inside or outside edge. Any changes to your suspension or steering rack will have an effect on your steering geometry. So you should get it checked and reset shortly after making any changes.
In actual fact, although lots of negative camber will eventually wear the inside edges, incorrect toe settings will kill tyres far more quickly.
Most cars are fairly tolerant of camber - especially with radial tyres.
The problem is that if the camber is out, most likely so is the toe.
Also, Golfs understeer...so you end up scrubbing the outside edges if you drive hard. I run -1.85 degrees negative per side and 2 minutes toe out per side (4 total) which would be considered a fairly extreme set up for road use...and I have fairly even tyre wear.
Slight inner edge wear over the outers...but when I was running parallel toe, it was perfectly even.
In my experience up to -2.0 degrees with parallel toe isn't too hard on tyres.
..but gaining motorcycles.
Offline lawson_gti
« Reply #22 on: 21 November 2008, 18:27 »
sweet!! i no now y 1of my wheels has a massive positive camber and the other a negative. wow guna sort that soon as even tho my golf is lowered 60mm all round a front pair of tires(this is with out wheel spinning, slidding tires on bends and just takin it easy) last me tops of 5-7thousand miles.  plus i have 1 tire on there from 2months ago brand new from mot an has 2.3mm lef and done 3k lol
so any ideas y this is then??
